After pushing on the end of the filter, it's nor releasing
SOURCE: I have the opposite problem
You may have air in the system. When you actuate the dispenser it opens an electric valve in back to start the flow of water. When you release the dispenser air in the system expanding will cause the water to continue to flow until the pressure equalizes.
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
SOURCE: Cannot remove water filter from LG 26 cu ft side-by-side in the d
turn water off to relieve the presher wiggle the filter and pull down on it. it will not bake you need to use force to pull it down and out of the refrigerator
SOURCE: Whirlpool Refrigerator: Side by Side Not releasing made ice.
The evaporator system that release the ice is not working, test evap
fan and motor , and test the heating coil on icemaker evap system.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
