My HP305 All-In-One wireless printer goes to sleep and won't start up when I attempt to print a document wirelessly. I have to go to where the printer is and cycle the power on and off in order to get it to print. Is it possible to configure this printer to 'wake up' when I send a document to it so I don't always have to manually cycle the power?
SOURCE: HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
SOURCE: Printer offline HP 4500 series wireless.
Hope this help. Please
Rate My Response! Thanks!
PREM
SOURCE: I have an officejet 6500
have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it
SOURCE: HP C310 Printer goes into sleep mode in 15 min of
open the my computer folder then open the printer folder then open the settings tap you can turn the enegry setting off no more going to sleep.
SOURCE: My HP Officejet 6500 Wireless
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
