Need to replace the lower element on our Amana ACF4215A oven. Do I get to the element through drawer removal or the bottom of the inside of the oven? Thanks, Sam
There should be two screws at the rear of the bottom panel inside the oven. Remove those and lift out that panel. The element is under there. If there is not enough wire to pull thru you may have to disconnect and reconnect the wires to the element from the back of the oven by removing the back panel. Hope this helps.
