Hello. I have a AMW6100/1, which is a front loader, and it keeps seizing just before the rinse cycle and the last two spin cycle light indicators i.e 0 and 100 flashes even though during the wash cycle it's constant on 1000.
Also before it seizes and during the wash cycle, which it doesn't complete the machine makes a clicking sound, as if it's 'struggling' to change to the next cycle.
Any advise for a DIY stint.....
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
SOURCE: water doesnt completely drain or spin during last cycle
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. This is the most common cause of this symptom on Whirlpool manufactured washers. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
SOURCE: i have a hotpoint aquarius 1000, model WM62, the
if the drum wont move even manuly u move it it is stuck the barings at the back of the drum have gone so it looks like you need to get it repaired cus it is a big job fixing a problem like you got.hope this helps
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
