Most times the hard drive is full, delete any thing you don't want ,to free up space . increase ram to four GB if you can. Get rid of add-ons Run a anti virus programe.
This is a function of the operating systerm that pages memory to hard drive. DOS didnt have this, but it started with windows 95. Linux and Unix always had I
Hey,
You got to free space on your hard drive. The virtual memory resides on your hard drive. but if the hard drive is getting full, this will reduce the virtual memory. So make home for virtual memory by free space on your hard drive.
Disable the Automatic restart on system failure option.
Remove any non-system disc from the computer .
During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
Reseat the memory modules .
If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory.
There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots.
Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
Reset the BIOS to default condition .
If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly.
To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
Perform a memory self test .
There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message.
If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors.
To run the memory test, turn on the computer and press f2 .
If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
If the BIOS Diagnostics screen displays, select Memory Test .
Reseat the hard drive .
If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive.
If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook.
Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
Test the hard drive .
If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing.
To run the hard drive test, turn on the computer and press f2 .
If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
to add memory, for increased virtual memory it is to delete msic data from the hard drive, if it is your hard drive low on space you should purchase another hard drive and make the new hard drive as the slave to store more, on it. if not have a bigger hard drive installed, obtain a USB external hard drive. to add increased more memory you have to open the pc, add another sdram/dimm/ddr memory card.
If you mean an USB pendrive/stick, these are much slower than hard drives. There are so-called SSD - Solid State Disks, which have a special construction (many Flash banks running in parallel) enabling them to offer transfer speeds comparable to a hard disk. These come as ATA or SATA drives that you connect just as you would a traditional hard disk.
RAM (Random Access Memory) are memory chips that the computer uses to run programming on the computer. This can be upgraded to the limit the computer will support, a good reference for capability of your system and a good source for purchase at www.crucial.com
The Hard Disk Drive, is like a computer filing cabinet where you install programs and store data on your system.
I assume, you are talking about combining 2 hard drives to create more disk space on your system. This is done by setting up a RAID (Redundant Array of Inexpensive Drives) To do this you will need a computer that supports RAID or install a RAID controller and configure 2 or more drives to create an array.
http://reviews.cnet.com/4520-11319_7-6386531-1.html?tag=rb_mtx;wp_body
open the back case of Hard and Memory..remove the hard drive then remove the memory...after u remove the memory try to clean the memory using a paper eraser then put it back the memory.about hard drive/Hard Disk do not put it back only memory to test and run the unit.if unit is back to power on self test try put it back the hard drive/HDD then try boot all system.if their is message hard fails i think u need to try to replace the Hard Disk...Thanks and Good Luck...GOOD DAY...
Your hard drive is getting to full for it to be used as virtual memory When normal memory gets used up windows uses the hard drive as memory ans if insufficient room on hard drive is not available you get this message. Solution. 1) delete programs from hard drive to create more space 2) Install new hard drive and transfer programs to it. creating more room on C drive 3) If hard drive is already partitioned and 2nd partition has a lot of free space transfer Virtual over to it.
Go to Start / Control panel Open The System folder go to "Advanced" "performance settings" Then to "Advanced " Click on change and set Virtual memory to new disk. Set maximum and minimum the same at 3 times the amount of normal memory you ave
Memory Applications
All data processing and execution takes place within the memory module(s). The program's directions are replicated into memory from a hard drive, external drive or from a network. The processor then extracts the directions from the memory and puts it into the circuit for analysis and execution.
Memory is so important that it cannot be wasted. RAM is allocated by the operating system and programs, and then released when not needed. Errant applications can grip RAM and not release it, which results in a diminishing amount of memory available as you load and use more programs.
If you could actually look into memory, you would be astonished. By watching how much and how quick data and commands are written in and out of it each day, you would realize it is a marvel that it works so we UpgradeComputerMemory.com is here to help you speed up and breathe new life into your computer by adding more RAM memory! We have hundreds of relationships with different manufacturers and carry all major computer memory brands. This includes Dell Memory, HP Memory, Samsung Memory, Micron Memory, Toshiba Memory and many, many more. We can cut through all that computer jargon and provide you with the part that will work each and every time. Our 100% guaranteed compatible RAM memory upgrades are available for more than 21,000 different computers, laptops, servers, printers and other electronic device.
