SOURCE: Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
SOURCE: My deep freeze outside will not stay cold.
a freezer is just a heat pump . from inside the freezer to the garage . the first law of thermodynamics says heat travels from a hotter to a colder surface . it could just be the cold how much are we talking?
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
SOURCE: Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Hello Donna F - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
