I bought a used Wagner 404 Plus airless sprayer. Is the motor supposed to stop when it reaches full pressure then start again when pressure drops below a certain point? My motor seems to go into a thermal overload and shuts down. Sometimes if I change to recirculate and then restart the power it starts up again. Is there a setting to adjust so it doesn't overheat?
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
SOURCE: Need instruction manual for a ''Wagner 404 Plus'' airless spray gun
I cannot get the sprayer to prime or spray
