Model is MC9090 -GFOJBEA2WA. When the scanner boots the above message appears. How do you enable the scanner?
You have a hardware problem with the scanner i am afraid. this will have to be sent for repair.
I encountered the same problem, I solved the problem by changing the laser component (Laser Scanner Engine).
good luck.
Give me a call on Monday 4/13 and send it in to me for repair!
Do you currently have hand-held inventory scanners?
Although you may not be familiar with Legacy's Technology Services, we may already be servicing your barcode scanners, barcode printers and even POS hardware. Many sellers of extended maintenance contracts have used Legacy for years to perform service on devices covered by their contracts.
Maybe you're looking for a specific hard to find part. Chances are I've got it!
We also carry refurbished equipment if you are in the market.
Give me a call for a quote and to discuss your current needs.
Joe Anselmo
Legacy Technology Services Inc
(847) 621-3300 ext. 418
Email: [email protected]
If you are in need of any more Symbol MC9090's? I have refurbished models that are in like new condition.
If you need your current ones repaired I can do this too.
Give me a call.
Joe
Joe Anselmo
It's usually a scan engine problem but as you've already replaced it it could be ribbon cable or CPU board connector problem
when you install the application scanner gives the error which leaves disabled the computer error A000000B
