No its never better to use a higher amp fuse because the system was designed to use a 40 amp fues.If you put a 45 in it, It will subject the system to 45 amps which it was'nt made for.
Click Start/My Computer then Right Click on the DvD Drive and select Properties. Click the Hardware Tab and double Click the Dvd drive or highlight it and click Properties. Click the DvD Region Tab and go down towards the bottom to change it by putting in a New Region.
if the valve timing is too far out the problem may be that one of the valves is open when it should'nt be & the piston is hitting it, if you try to keep starting the engine you may cause serious damage to it (if you have'nt already done so),it may be best to get a qualified mechanic to set the timing for you.....hope this helps.....cheers
they sell kits for restoring/cleaning lense.just a polish material sold at most parts houses works good & removal is'nt nessasary.may look like its on the inside of the lense but is'nt on most
how can i start it, it is not working
