I want to restore factory settings on my phone but dont know the lock code for nokai e71...
Press the keey on the left side of shift key. it will change the entry into num mode. press 112 and press dial button (green phone button). It will show connecting press end call button. Now the set should be in normal mode.
I had the same problem and tried this:
Tools Required :
• Nemesis Service suite (NSS)
• Nokia PC Suite
• Data cable
Steps :
1. Connect your phone in PC Suite mode
2. Open Nemesis Service suite (NSS)
3. Then click on scan for new devices button (top right hand side)
4. Click on phone info button.
5. Now Click on Scan.
6. Select Permanent Memory.
7. Click on Read.
8. It will read the permanent memory file and save it on the disk at following path.
C:\Program Files\NSS\Backup\pm\<IMEI>.pm
9. Open the .pm file using Notepad.
10. Now scroll until field [308], and on the 5th Record (5=) your security code is saved at there.
11. Like 5=31313131310000000000
12. Remove all “3” digit and it will be 31313131310000000000
13. 11111 is your security code.
My security code was the default 12345 so it was unchanged.
Go to Tools, Factory Settings, choose Full Factory, Reset
Reboot your phone and put in date and time -> the question for the security code is disappeared
Thanks! it works!
where can i get nemesis service suite
and what do you mean about : Connect your phone in PC Suite mode
my phone as lock pls i need a master code IMEI: 354855028087384
My Email is [email protected]
phone mode Nokia E71
My mobile is 2348067179541
when I click on scan button in NSS in says "error". what will i do?
If NSS give error message uninstal all parts of Nokia PC Suite, then instal a older version. I try with PC Suite version 6.83.14.1 and it works ;)
i forgot my e71 phone lock code, how i can get?
great that was a gud idea, i tried it and it worked, thanks buddy...
Lock code - 12345 - unless you have changed it
New E71-2 (North America) owner here who bought an Ebay special that the previous owner "factory reset" and had the "screen lock". when I got it. I tried all the "easy" fixes I could find (default code, hard/soft resets, green/3/* power on, etc) to no avail. Really can't do much when your keypad is locked! Finally got desperate enough to try Nemesis as suggested in solution #3. My result?---Guess what, code WAS the default 1-2-3-4-5 and STILL my phone wasn't accepting it for whatever reason...go figure
So, many frustrating hours later, here's what I came up with from from my "research" and "experiments".....
Temporary fix-
Calling 112 and quickly hanging up (Careful here-as this may be an emergency # in certain parts of the world). This will clear lock code-until you off/on the phone. Then it's back
Permanent fix-
If you went as far as trying Nemesis to get your code and STILL no joy give this a shot (I really just stumbled on this, but hey, it worked!) While in Nemesis and Nokia suite (follow solution #3) , go to "tools", factory settings tab, and click "full factory" and then "reset"
That's all it took- LOCK SCREEN GONE BABY!
This solution does require usb connection with Nokia suite and Nemesis, so you'll have to use the temp solution in conjunction to access phone keypad/menu and change usb settings to connect phone to pc
You can find Nemesis (NSS) on the web, (it's a freebie), no instructions (that I could find), but not too hard to use... or there's always Nokia service!
Good Luck!
And thanks to rkjnssn in solution #3 for getting me started in the right direction!
Now happy E71 owner, awesome phone!
To reset your Lock Code...Just download Nokia Suite Store and use Refurbish option. Refurbish will reset your phone as manafacture thus removing the Lock Code.
http://rapidshare.com/files/300421794/Nokia_Care_Suite_Store_2009_13_0_www.unlocking-gsm.blogspot.com.msi
The default is 12345, if you cannot open it, then the previous owner had changed it. there is a possibility to hack the firmware but it is better to send to Nokia Service Center to do so.
It is 12345, but be sure to hold shift key while keying. So you are entering the numbers. Otherwise the phone takes your entry as alphabets and it won't accept it.
Once you have keyed five wrong consecutive attempts, the phone will not accept even the right lock code after 5 mins, so wait another 5 minutes to figure out the lock code, just tried it now.
for example: let's assume that the right code is "12345"
but you entered 00000 on five consecutive attempts, and then you entered the right code which is "12345" the phone won't accept it, even if it is the right code... just wait for 5 minutes and try again. this is out of my personal experience.
I had a problem with lock codes my Nokia N61 would not accept the default 12345 code, kept saying code not correct, I tried everything, had to wait 5 minutes each time I entered it 5 times incorrectly. What finally worked for me was not to use the shift key so I was typing in the corresponding letters and not number "rtyfg" - silly I know but worked for me!
Salam 3ANDE E71 KHASNI CODE SOUKER WMABGHALICH YTFTA7 JARABT 12345 0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 DONA JADWA
تليفوني علمت ليه تحديثسوفت ويرمن لنت وعند اعادة التحميل طلب لوك كود
I tried using nemesis as described. I reached until read in permanent memory stage. but the pm file is empty in my program files. Cant find <IMEI>.pm there Any solutions please?
00000 (Five zeros) worked on mine
I really need to say thank you for kdc52 his way is hopfully workin hoo man you sefe my life ^^
Thanks and God Bless you Jesus Loves you.. Jesus isLord hallelujah amen and amen : )Praise king Jesus and The Holy spirit Praise God Praise King Jesus Thank you God for everything amenand amen and this!!amen and amen
lock code appear after upgare the software
regtergdfg
I am experiencing "nokia e71 lock code" problem after upgraded the latest release of software. Anyone has any idea to resolve this? "12345" does not work.
after upgrade of software for 200. xxx. I have permanently request of " Lock code" . If somebody has a solution for this issue.
Thanks in advanceÂ
I didn't upgrade any software and am experiencing a Lock code. Does anybody know what should I do?
i tried nokia E71 lock code more than 5 times so pls help me to find out master code
Hi I am using Nokia E71 and i just configured Exchange Server Email and it git connected. After connecting it aut matically locked and asking the lock code. I do not know what is this lock code and i have not set any lock code. Can anybody help me out on this.
Thanks in Advance
this nokia e71 i have is asking me for a lock code and i think it was change by the previous owner does anybody have an idea of what i can do
Folks Please help, i tried both methods and i cant get it to pass the lock screen. I tried 122 call, and quick end call its goes immediately back to the lock code screen. I connect it to Nokia pc Care suite, same thing, i cant get the software to recognize the phone when conencted, so it wont read it, neither with Nemesis, it wont read because it gives an error hen connected, i think it wont recognize the phone. It wont read it no matter what. I have installed Nokia PC suite for Nokia e71x, the same as mine so all drivers are installed. Please help !!
Thx,
Martin
Mera Nokia e 71 phone ka password kaise open kru m password bhul gya hu
