SOURCE: 2007 street glide misses and wonts to stall out when taking off??
my roadking just did the same thing, check the gasket between carb and intake
SOURCE: how much air should I put in air shocks 2010
Don't mean to sound nasty but I thought new hogs have on board compressor to keep shocks,front and rear filled up?Your shocks need air maybe compressor aint working?Just a guess,sorry.
SOURCE: how to attach kick stand spring
Take the bolt out of the kickstand, attach the spring, then use the kick stand for leverage to stretch the spring, and re-install the bolt...
SOURCE: Oil seems to disappear out of my 08 Street Glide.
on the air filter backing plate the two bolt that hold it to the cyclinder head are hollow and part of the engine or crankcase breathing system when the pistons are on the down stroke this creates pressure and so to vent this out the air travels up threw to the heads with the oil and there is a little filter to catch and stop the oil and allow the air to pass out thew to the atmosphere however it does carry some oil with it . Old school used to vent out to the chain and help lube it.Now with the EPA rules it vents into the air intake system and the oil burned with the fuel.You can change the filter element which is under the rocker covers.
SOURCE: have a 2010 street glide with harmon kardon sterio
do you mind me asking why you want a head phones on your bike? well anyways this is what you need to do, go down to radio shack and get a hook up and if your able to find a switch to turn off the main speakers so just your head phones are on. remove the head unit and locate your speaker wires now solder in the jac. best of luck if you need more help please contact me
M.Woodring
