The brush is spinning but there is very minimal suction, not picking up most stuff
SOURCE: Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
SOURCE: my kirby has no suction
Even if you have a new belt, do everything this guide tells you to do. The seller may have the power nozzle assembled improperly. If the brushroll is in wrong or the base plate is not on correctly, it may cause these symptoms.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
SOURCE: No suction on kirby g4 upright vacuum. Can't use attchments.
First remove the mini-emptor and check for a clog also check the fan for anything cloging that or the hose may be clogged
SOURCE: kirby sentria
you have to make sure the green light is on.. in the corner .. and if it is that means its working properly. If you have no suction then it is usually the belt and or the bag. so make sure your bag is not full , make sure everything is attatched properly and the green light is on.... The Kirby is the best vac out there and little suction should never be a issue for us.. I am a proud owner of the sentria..Love it..
SOURCE: How do I connect upholstery cleaner to Kirby Sentria
Here is a link to available owners manuals...
http://stores.shop.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQ_fsubZ7656839QQ_sidZ122982163QQ_trksidZp4634Q2ec0Q2em322
Hope this helps,
Marci
