I just bought the notebook "Asus A53S" notebook, I added a 4GB ram so it had a total of 8GB RAM, but within a week, it started to have bluescreen, I checked my laptop that it has no virus, but why bluescreen always shows...? (next time i will take a screenshot.....) Spec: intel i5 2430 NVIDIA G630M 1TB Harddisk 8GB ram
The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did.
I would suggest to use a system utility tool like Reginout to fix this problem instantly.
SOURCE: Problem with upgrading my acer extensa 5620z memory to 4GB
The Extensa 5620z comes with 1GB of DDR2 memory. That's two sticks of 512MB. This unit technically supports 4GB; 2 x 2GB modules. However, unless you're running a 64-bit operating system (if you have to ask how you'd know, trust me... you're not) then only about 3GB will be usable. There's no fix for this, it's just a fact. All standard 32-bit operating systems are coded this way
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Will Sony laptop Vaio VGN-S360 support 2GB RAM?
No, it will not. So do not waste youre time and money trying it.
SOURCE: blue screen error while installing XP in acer 5630 with 4 gb ram
Boot your computer with winxp disk then follow the procedure.
Press enter for install new xp then you see partition delete all partition then create again then install xp in first partition try this 3 to 4 times so that error not comes .you can do it.
Let me know if you need more assistanse.
Thanks.
SOURCE: Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Testimonial: "Thanks Mitesh for the information its was very useful"
SOURCE: blue screen with 4gb, OK with 3gb of RAM on 6720s
A 32bit OS and Processor is able to Identify and work with upto 3GB of memory.
That may be the cause of the issue
Even if any computer has more then 3gb of ram it will showup only upto 3gb.
if you install 4gb or more then also it will not show up.
.........and second reason, may the ram that you are using are not identical or one of them is not working properly.
Check the specifications of the ram and also try using one a time.
Thanks and Regards
