Question about Gateway Computers & Internet
Recharger cord is shorting out or not chargeing right
    Sergeant:
  • 237 Answers
Is the cord frayed at one end? Is the connector at the end of the plug bent?  If any of these is true, just get a new cord, problem solved.=)
Posted on Nov 18, 2008
SOURCE:
Braun 7series will not recharge yet will work because she still has power in it what can I do when the charge finishes
If it is not recharging, you have a problem with the cord or the charging system (circuit board). You will need to determine which.
If new cord is needed, you will find at shaveroutlet.com.
You will need to know your specific model number is circuit board is needed.
Braun Replacement Charging Cord for Pulsonic and Series 7 Models and More
Jan 02, 2017 | Braun Health & Beauty
Tip
Properly recharge the battery of a laptop
<span><span>The</span> <span>best use</span> <span>of a</span> <span>battery,</span> <span>regardless of</span> <span>its use</span> <span>(</span><span>PC</span><span>, car</span><span>,</span> <span>rechargeable lamp</span><span>)</span> <span>is</span> <span>still</span> <span>work</span> <span>to do</span> <span>in</span> <span>charges</span> <span>and</span> <span>discharges,</span> <span>otherwise</span> <span>it</span> <span>gets used</span> <span>(</span><span>it</span> <span>keeps the</span> <span>memory</span><span>)</span> <span>load</span> <span>short</span> <span>and</span> <span>even</span> <span>totally</span> <span>d&eacute;cherg&eacute;e</span><span>,</span> <span>most</span> <span>will not resume</span> <span>its</span> <span>initial capacity</span><span>.</span><br /><span>A</span> <span>laptop</span> <span>is</span> <span>made</span> <span>to go</span> <span>in nature</span> <span>and</span> <span>therefore</span> <span>to work</span> <span>regularly</span> <span>on</span> <span>drums</span><span>.</span> <span>A</span> <span>PC</span> <span>that</span> <span>remains</span> <span>permanently</span> <span>in the office</span> <span>sector</span> <span>will see</span> <span>its</span> <span>battery</span> <span>quickly</span> <span>died</span><span>.</span></span> <span><span>The</span> <span>best solution</span> <span>is</span> <span>to</span> <span>unplug</span> <span>the</span> <span>power cord</span> <span>as</span> <span>often</span> <span>as possible when</span> <span>the</span> <span>battery</span> <span>is</span> <span>fully</span> <span>charged</span> <span>and allowed to</span> <span>drain</span> <span>up to 30</span><span>%</span> <span>capacity</span><span>.</span></span> <img src="nidalkom01_10.jpg" />
on Jan 08, 2011 | Computers & Internet
Hp pavillion zv6233nr
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
May 05, 2013 | HP Pavilion Computers & Internet
Acer model zlr wont work unless pluger in to charger cord
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 21, 2013 | Acer Computers & Internet
My laptop goes off when I unplug the cord from laptop!
Nov 30, 2012 | HP Pavilion dv9000z Notebook
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
Battery not holding charge on Alesis transactive pa system. Power cord connected and keeps turning off.
If the battery is old, say three years, it may be worn out. Fully discharging batteries or using them beyond where they have noticeable loss of power results in reverse charging the weakest cell which then often shorts rendering the battery un-rechargeable.
Aug 01, 2011 | Alesis TransActive Mobile Speaker PA...
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
Tom Tom GO720 wont recharge with car charger inn car, but does charge on USB
either your car charger cord has a short or break in it, or your charge port (lighter socket) dont work. check your fuses to see if it aint something there, then try to find another cord. It wont be a prob with your TT as it is still able to charge from usb. The problem has to be on the car or car charger (still should be an easy fix)
Aug 03, 2010 | GPS
Charge
You need a separate battery charger for this camera. It does not have a battery charger built into the camera itself and can not be recharged thru any cords connected directly to the camera. The USB cords only transfer the files to the computer, they don't recharge the camera.
Dec 30, 2008 | Sony Cyber-Shot DSC-P50 Digital Camera
Computers & Internet Logo
15 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
