I have hooked up the driving lights to the fog light fuse but that is wrong . I want to hook up to the low beam circuit of the car so that the driving lights can only be used when the car is on low beam . I do not know where I have to connect the driving light power wire to the low beam wiring of the car . Can you help me with this ?
SOURCE: No Hi Beam on 93 Camry
The headlamp circuit is rather simple. From the 15 amp RH headlamp fuse, there is a red w/yellow trace that goes to the RH high beam. Out of the 15 amp LH headlamp fuse, the wire going to the LH Hi beam is solid red. Both of these wires should have power when the headlamp relay is energized. The wires from the Hi Beam bulbs going back to the switch should both be red w/black trace. The wire going from the headlamp relay to power the 2 15 amp fuses is white. The headlamp switch applies a ground to illuminate either the Lo Beams or the Hi Beams.
SOURCE: Can i connect fog lights directly to low beam lights????
I would not connect them without a relay, because it will put too much amperage through the stock wiring and could possibly melt the wiring and catch fire. This This is too nice a car to let that happen to.
SOURCE: I have a 1999 Dodge Ram, I just replaced the
Why this isn't a total solution, one resource I've used many times when it comes to electrical diagrams is http://www.the12volt.com/. They have all the diagrams and "audio experts" there that might be able to tell you specifically the color.
SOURCE: 2002 subaru outback light wiring?
Below is a link for the wiring diagram you requested:
2002 Subaru Outback Wiring
SOURCE: I am hooking up plow lights for a 2001 dodge ram
on back of lights look at color wires the ones coming from high beams and the low beams theres your color wires there
