Android os 2.2 kernel 2.3.32 build number 1.5.5
SOURCE: The application Calendar storage (process
It is safe to select force close, however any unsaved work will be lost. Restart the application afterward.
SOURCE: every time I open my galaxy tab. I can not access
touch and hold on pressing the home key until a task manager note will pop out end the recent tasks or uninstall the programs that u suspect making problems. my galaxy was having problems with viber and what's up communication apps i uninstalled them and the problem was solved automatically
SOURCE: when i turn my android
Hi there
There is a reset hole. Please insert an unfolded paper clip and push the button for about 10 seconds.
Let me know what happens.
Thank you for using Fixya!
SOURCE: Hi, I bought Smart Epad 7" I had error of The
You can restore your epad to factory settings by going to the settings menu > privacy > Factory data reset. and then your epad should be running normally again.
SOURCE: all I'm getting on the screen when I cut it on
Hi shannon2188,
Please follow the steps below to correct the problem.
1. Press and hold the on button. Keep it down.
2. At the same time, keep a finger on the screen.
3. Keep watching and you might see a slight change of color on the screen.
4. Hold it down for 15 seconds or more. Be patient.
5. You should get the battery icon or the system will just reboot.
6. Once you get the battery icon, you're set. Just press the on button for 10 seconds and the tablet will shutdown.
7. Now power up as normal to reboot.
Hope it helps.
Thank you for using FixYa.
what do I do to my tablet to fix the problem?
solution for stooped (process com.wmt.lancher) ?
