Question about Casio Exilim EX-Z750 Digital Camera
Displays Table of Numbers on LCD before each picture
Every time I attempt to take a picture, a 2 column table of numbers with the headers 'Total' and 'Delta' appears on the LCD. I can hit any button and it'll go away, but the table re-appears every single time I want to take another picture. It doesn't prevent me from taking the pics, but it's hard to set up a picture with this stupid table always in the way. I've reset the camera, re-formatted all the memory, re-applied the 1.02 firmware. Don't know what else to do. Any ideas? The table looks something like this: TOTAL DELTA 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 Thanks! David
  • 374 Answers
That sounds like a service menu. Did you recently have your camera sent into repairs? Try resetting your camera and see if that goes away. In REC mode press menu go to setup tab go up until you see reset press right arrow & highlight reset press set. Hope that works for you.
Posted on Jul 14, 2007
SOURCE:
My husband needs to replace table top clamp for Delta Shopmaster table saw #905657, 9.5 saw blade, 17x26 table top. Need to know table top clamp order #.
Hello, Ruth -
I have not had any luck in finding the part number for a replacement table top clamp for a Delta Shopmaster table saw #905657. Which means I am unable to provide you with a part number.
Instead, I suggest you contact Delta directly. This is the link to the Delta tools home page:
http://www.deltamachinery.com/
Scroll down the home page and click or tap on the Support link.
On the Support page, you will find the toll free telephone number for Customer Service. Call that number, Monday-Friday 8 am - 5 pm, Eastern Time Zone. There is also a link you can use to send an email asking about the model number for the table clamp needed.
Note: Personal opinion: Not all of us who volunteer to answer questions for Fixya.com are no-helpful-information jerks.
Best wishes.
Apr 30, 2018 | Delta Saws
How do I get a total?
Every time you enter another number, when you hit the plus button, the new number that appears is your new total. If not, try the = button
Jan 16, 2015 | Innovera 16015 Desktop Calculator, 12digit...
I need the FrontPage manual.
Adding Pages To Your Website Using FrontPage Now that your website has been created in FrontPage, we can add some web pages to it. Click File > New > Page. Choose the first tab (General) to select a regular page. If you click once on each page you can see a preview and description of it.
Importing A Web In FrontPage
To import a web click File > New > Web. When the New dialogue box opens, click on Import Web Wizard.
Add a border In FrontPage
To add a border to your image in FrontPage, right click on the image and select Picture Properties. Go to the Appearance tab and adjust the value for Border thickness. You can change it by either typing in the number yourself or by clicking and holding on the up or down arrows to the right of the input box
Creating a Table
A quick way to create a small table is using the table button on the standard toolbar.
Click the button and drag the mouse over the grid, highlighting the cells that should
appear on the table. When the table size has been selected, click the mouse button
again.
z79myfziej+gabfjgi4ont+pzsfbefbimpu0r8se3pw5el8ipgg2u8359wgq82wqcd+gatd1rwwscpx0hhssvja8abpgac4apaat4ahoadwae+abzga8dbf9c+q4nf6tb0aaaaaelftksuqmcc
A table outline with 2 rows and 2 columns will appear on the page:
for more details go to the following link :
http://198.86.242.37/news/printshop/tutorials/frontpage/Beginner%20FrontPage%20Tutorial.pdf
Jul 06, 2011 | Individual Software Professor Teaches...
How to make a 7 row and a 7 coloum in a spreadsheet
Creating a table in Microsoft Excel 2007 allows you to work with that data independently of the rest of the worksheet. First you must define your table, though, which you can do either from scratch or from data already in the worksheet. The process is a simple one. Read on to learn how to define a table in Excel 2007
  • Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
  • Click on the "Insert" tab at the top of the document.
  • Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
  • Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
  • Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
  • Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
  • Thanks for choosing Fixya............ Sandeep
    Mar 18, 2011 | Computers & Internet
    Hi. I made a web page in Frontpage. When I see it
    The tables are probably nested incorrectly as changing the aspect ratio is moving images. Keep in mind that each row must have the same number of columns, so to keep it simple, the base table has one column, and you need to create a nested table in every row that needs more than one column.
    At the very least, create a table for the whole page, and nested tables for each section. Use this template as a guideline:
    Default
    Header
    • The
    • menu
    • goes
    • here
    "Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum."
    Footer
    Mar 06, 2011 | Microsoft FrontPage 2003
    How do you get the table ([2ND GRAPH]) from the [STAT] [EDIT] [L1] [L2] list to appear with [Y1] in the second the column? The information appears in the scatter plot, but the information in the table does...
    Instead of hitting the [table] button. You should hit the [stat] or [stats] button as I forget which it is. Then hit [enter] which will bring you to a stats list editor of some kind. You will want to enter the data for your x-axis in L1 and the data for your y-axis in L2. Once you have completed your lists, hit the [stat] button again and then click [right] or the right arrow in order to move to the section of calc. from number 4 down it will help create a graph of that type of function. lets say you think it is linear, so you hit [enter] on number 4 and then you will be at the home screen with LinReg already written. You just have to complete the statement and it will do it for you. hit the [2nd] [1] and then the comma button, then [2nd] [2] and [enter]. that will do it for you.
    Feb 14, 2011 | Texas Instruments TI-84 Plus Silver...
    When adding a column of numbers it will keep a runniing total, but as soon as I hit the total button it rounds up to the next figure and will not give me a true total. What do I do...
    On the K.A, at the top, have it set to "A". Where it is F 6 3 2 1 0, set it to "2". Then turn it off and back on, that solved it for me....
    Jul 14, 2010 | Sharp EL-2196BL Calculator
    Motor labors on startup. Kicks off 220 v breaker. Just happened. Been using Delta Unisaw for years. Motor doesn't get hot or smoke.Last time it was working well and I went to hit the red stop button I may...
    could be a couple problems without knowing what motor the starter windings could be burnt or the capacitator might be bad. I would suggest going to Dewaltservicenet.com and typing in your model number to see if you can find a breakdown there. If not send it to me and I will try and locate it for yo.
    Sep 17, 2009 | Delta Saws
    Application of Pivot table & Sub total with Examples
    Suppose you have a Database regarding sales of this Month inthe Column and Row Fromat with column Heading SalesPerson, Company, Product and Amount. where salesperson sales to different company different Products more than once. In this type of Database Salesperson, Company and Products appears more than once. Now you can use PivotTable to view and analyze your data in different Formats like Salesman wise COmpany wise and Productwise with different formatting REports with a facility of Preparing Charts too.
    Dec 03, 2008 | Computers & Internet
    Restict closing the main form when some controls on the subform are empty
    Hi there. I didn't notice this was so old until I had already worked on it for some time. Did you get this the way you want it? If not, I suggest either using a BeforeUpdate control to ensure the condition is met that the subform contain data, or validate the particular field(s) with isnull. Thanks for posting back if you still need help, or otherwise rating FixYa!
    Oct 03, 2007 | Microsoft Office Standard for PC
    Casio Exilim EX-Z750 Digital Camera Logo
    338 people viewed this question
    Top Casio Cameras Experts
    Ekse
    atollminsk
    Level 1 Expert
    Parshiv Luthra
    Are you a Casio Camera Expert? Answer questions, earn points and help others
