Contributor
- Posted on Apr 29, 2012
Re: Do not have a nintendoDSI operations manual to reset...
How to Remove Parental Controls:
Use the information below to remove any Parental Controls that have been put in place.
- On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon.
- Select the right arrow twice to reach the third page, then select "Parental Controls."
- Select "Yes," to change the parental controls.
- You will be prompted for your 4-digit PIN.
- If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
- If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
- If you do not know the answer to your Secret Question, tap "I Forgot."
- The screen below will appear. Look at the top of the upper screen to see the date your system is set to, and make sure it is today's correct date.
- If the date is incorrect, it will need to be changed in order for us to assist you (how to).
- Type your eight-digit Inquiry Number in the box below and click "Continue."
Note: You must contact us on the same day that you get your Inquiry Number from the Nintendo 3DS
