Question about Mercedes-Benz Vehicle Parts & Accessories
Reprogramming electronic gears for actros 1835 mp1 truck after removing gear box
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 63 Answers
Is a very complicated solutions only to be maybe by computer need to call a mobil diagnostic fault finder or take truck to merceds garage
Posted on Apr 29, 2014
SOURCE:
Way is it hard to shift down on a g240 box
just 1 possibility is this, Mercedes Benz Actros Replace gear sensor the other is you are just going to fast for the gear.
May 27, 2017 | Cars & Trucks
How to reprogramm electronic gears
Have to be taken to a dealer most of time so they can put a dignostis code scan to set. Good luck on it.
Nov 25, 2014 | Mercedes-Benz Mercedes Bentz Actros Semi...
Why will the gears of my actros truck not workafter fitting new clutch
well a description of the problem would be a big help
does the gear crash when the clutch is pressed in
can the gears be engaged cleanly when the engine is stopped
did you install a single plate clutch or duel plate clutch
if the gears worked properly before removing the box , then the problem will be in the clutch plate fitting ( wrong way round and the hub is hitting on the flywheel bolts or duel plate on clutch bub is incorrect hitting on the other clutch hub)or the gear shifter installation after fitting the box
Sep 13, 2014 | Mercedes-Benz Mercedes Bentz Actros Semi...
I have an actros mp1 v8 3348 model with a 542 engine, the truck has a hard start before the truck van start uou musy spray quick start. I bought brand new injectors from Mercedes, changed the banjos bolt,...
ur problem seems ignition--inspect distributer cap inside or test coil--worn plugs and cables will also giv a weak spark---cant tell health of electrics from outside--wear is usually internal-----------may want to do a datastream scan of vehicle--it uses factory gear-private shops not dealers do this
Jul 11, 2014 | Cars & Trucks
My actros 3351 firetruck,is jumping from gear when you engaged it to reverse gear
The indent spring may be broken on the selector shaft. If not the gear box will have to be removed and repaired , May be very expensive .
Jun 29, 2014 | Cars & Trucks
Gears do go in but my truck cant move
may be you have applied the emergency brakes. or else brakes are stuck. see if you can drive reverse
Feb 10, 2014 | Mercedes-Benz Mercedes Bentz Actros Semi...
Mercedes actros fault gear change
Hi Pat, carry out a diagnostic scan. That will pin point the problem so that you can get it rectified. I've known the same problem to be reported from a number of Actros owners, so its not uncommon. Regards John
Oct 20, 2012 | Cars & Trucks
Mercedez benz actros is stopping in gear and clutch not working , what will be the problem?
There are multiple problems that could cause this.one of them being excessive pressure to your clutch servo.check the air-dryer,make sure it is releasing.
Feb 17, 2011 | Mercedes-Benz Revell 1/24 Mercedes-benz...
Mercedes C-203 automatic transmission does not
At sounds like a problem with the E.P.S Hve you checked to see if the Air pipes feeding the unit arn't broken or caught. Might even be a broken selector fork in side the box. the old 1825 merc 6x4's Had a similar fault especially the ones on D and E reg
Mar 10, 2009 | Mercedes-Benz Mercedes Bentz Actros Semi...
Vehicle Parts & Accessories Logo
95 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
