SOURCE: Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
SOURCE: F & P Double Drawer
Are you sure of the model?? flash a U3 the following is from The FP Manual on the DD-603 Model...........
The last two faults are logged into EE memory.
The other U (user) faults have been removed. The old U2 fault, which was the tub forced open during a cycle, has
been removed completely. Instead if the tub is forced open the product simply pauses as if someone had pressed
the start/pause button. The old U3 fault, which indicated a failure to drain i.e. water left in the tub, will not show up a
fault and the DishDrawer will continue through the cycle
SOURCE: dishwasher f1 problem
thanks for the follow up. I ended up calling a service representative in my area to complete the repair.
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
SOURCE: Fisher Paykel double drawer dishwasher DS6031
you have an overflow leak problem....shut off circuit breaker or pull fuse....let it dry out for up to 4 days; hopefully overnight; peak under dryer and feel metal drip pan and if wet you might be able to dry with a hair dryer...WHY? the lid did not seal when you put cycle on...the lid lowers and you had something..typically too bid glasses on second shelf that was above the seal lip of the tub...stack correctly after this and no worries...
What is the number for the service tech?
