kawasaki PVS1965 Portable DVD Player Logo
Posted on Apr 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i get a printed ribbon to purchase
Cant get it to read anything
Anonymous
Level 3:
Top Expert:
  • kawasaki Master 14,553 Answers
  • Posted on Apr 30, 2012
Anonymous
kawasaki Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718398
Points
48227
If you are saying the unit will not read any discs you have either a dirty or bad optical pickup unit in the player.
Why would the printer not print appears like it has run out of ink(is a thermal)?
That printer will work in both direct thermal (no ribbon) and thermal transfer (ribbon) modes. If you are using media designed for thermal transfer printing and don't have a ribbon it won't print anything.
2answers
Brother SX 4000 stopped printing. Ribbon is
Remove and inspect the ribbon cartrige, wind the knob and make sure that the ribbon moves and reinstall. Check that the correction tape is installed properly. Check that the ribbon plate assembly is not in the correction position. Try CODE RESET (Q key)
2helpful
Cant get the typewriter to print
Be sure the the ribbon has not run out or is jammed. You can test this by rotating the colored knob on the top of the ribbon cartridge in the direction of the arrow imprinted the housing.
If not, do you hear the click of the hammer striking the printwheel? If not you may have a defective main board or hammer solenoid.
No print with ribbon
Did you put a ribbon in your printer? The zebra does both direct thermal and thermal transfer, but you need a ribbon to get it to print AND have to change the settings to let the printer know that it needs to use the ribbon instead of direct thermal.
Bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Purchased Rover 5000 Super Delux on ebay for xmas present.
Try this push the platen (black rubber roller) down firmly on both sides they do pop out of position.
DickyO
2answers
I downloaded the new 2.4 update and now my ps3 wont read any games or movies
same here! and wen i call the dumb customer service number, i cant get a hold of an actual person. how ****!
Problem with my Epson Dot Matrix printer
Chances are, you didn't installed the ribbon correctly...
A. Open the printer cover
B. Use a pin to guide the ribbon between the print head and the ribbon guide, then turn the ribbon tightening knob to help feed the ribbon into place, it shouldn't be twisted or creased.
C. Slide the print head from side to side to make sure it moves smoothly
2answers
Detachable face
Either the back light lamp is burned out or if it is also a flip face, then you may have a "wire" on the ribbon cable to the flip face that is broken and then you would need to replace the ribbon cable. If it is a flip face then I would strongly suspect that it is the ribbon cable.
Top kawasaki Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
