Question about Whirlpool LER6636PW Electric Dryer
Dryer seems to work, but clothes end up damp?
I have a Whirlpool with the AccuDry humidity sensor system. It's about a year and a half old, and for the past few months, I've had an issue with the AccuDry not working very well. At first, the suggested dry setting would leave clothes damp, so I had to select "More Dry." Now, even the maximum dryness ("Jeans") leaves the clothes damp. I bought one of those dryer cleaning kits and ran the brushes through the filter area and the vent hose, but there didn't seem to be any lint clogging. The hose is not pinched in the back, but because it's long to allow me to move the dryer to reach the backside, it comes out the back of the dryer, smoothly bends (no pinching) 180 degrees to go back towards the floor, then another 90 to go to the wall. I see plenty of steam coming out of the vent on the side of the house, too. It's tumbling fine, and everything gets hot as expected, but the clothes just don't come out dry. It doesn't appear to be a matter of load size, either, since even a half load comes out damp. An extra spin cycle in the washer only helps a little bit. Any suggestions? Thanks!
  • 2 more comments
  • Corwyn Miyagishima Dec 21, 2006
    Wow, you were right!
    I had (erroneously) assumed that since I could see air/steam coming out of the vent outside, that everything was fine. It's a real pain to get behind my washer and dryer, but when I went back to disconnect the line, I figured that I might as well check the end that goes into the wall (and to the outside a few inches later). I stuck my hand in, and was met with a soft mass of lint clogging up the vent to the outside. A quick vacuum got rid of it all from the vent to the outside and any bits that were stuck inside the vent tube. I have a load in the washer now, so we'll see how it goes. I'm pretty sure, though, that my problem will be solved (I'll report back if it doesn't). Thanks a lot!
  • balcap Nov 10, 2007
    we have checked the vent line, but perhaps further down the run it is clogged. today the dryer started "tripping" the circuit breaker. This may be a coincidental event with the breaker, but the dryer continues to not dry completely. we will check further down the run and see if there is a problem. Any other suggestions?
  • Anonymous Nov 30, 2007
    We have the same problem with the dryer heating but not drying the clothes. We have checked the vent and were able to put a ball all the way through it so I have to assume that there is no blockage. We have also run a load with the vent open at the back and the clothes were still damp.
    I think it might be something to do with the thermostat or sensors? (it's a 5 year old GE dryer)
    We've had a repair guy look at it, he replaced a thermostat and charged us $100 and the dryer is still doing the same thing. Should I just cut our losses and buy a new dryer?
  • Sam Rosa
    Sam Rosa Jan 23, 2018
    NO, call him up and tell him about this situation and ask him why? if he tells you the heating coils are good but he thinks it`s ???. call a parts place and see how reasonable the part is and if it`s okay, buy one and look on youtube on how to put the part on. it`s easy! try it! I`ll bet you fix it.good luck!
    Scholar:
  • 76 Answers
Corwyn, looks like the problem you are having is not with the dryer. The vent line is probably clogged up, which caused the moisture to stay inside the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. Gendos....post back.
Posted on Dec 21, 2006
    New Friend:
Thanks you guys... This is not the first problem I've come to get my answers on from Fixya! I unplugged my dryer hose from the wall vent and viola or in hood terms "Boyahh" clothes are drying! Precciate it!
Posted on Jun 09, 2010
I just wanted to say a thanks to Corwyn for the clogged hose because that was my issue with my dryer .. I would of propably bought a new dryer. So thanks again you saved me alot of money .. from Mary
Posted on Oct 21, 2007
4 Suggested Answers
SOURCE:
  • 583 Answers
SOURCE: whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Posted on Mar 03, 2009
catriver
  • 878 Answers
SOURCE: Whirlpool GEW9200LQ0 Gas Dryer
Andeb, 90% of the time long dry times are caused by blocked vents. If you are sure that this is not the case there are a couple of things to check. First check the sensor; press the more time button and less time button 4 times until 88 shows in the display.(more time,less time, more time, less time). Open the door and you will hear a beep and a see a code. On the inside just below the vent screen is the moisture sensor. Moisten your finger and lay it across the sensor strips covering both. If you hear a beep, the sensor is good. Sometimes they build up with fabric softner and need to be sanded lightly. Another issue might be the burner coils. Remove the bottom panel and check to see that the burner is igniting and remaining lit. Sometimes these coils become week and will not sustain the flame. I will attach a diagram, look at number 13 and 14 on the picture. These are the coils. Catriver..post back.
Posted on Sep 18, 2006
  • 21 Answers
SOURCE: Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Posted on Sep 08, 2007
Why does drying cycle end with clothes damp?
The dryness sensor is dirty or has failed
Oct 15, 2015 | Dryers
Dryer not tumbling
It's probably the belt that turns the drum. They're easy to change and inexpensive too.
Oct 30, 2013 | Whirlpool Traditional Electric Dryer with...
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
Whirlpool Cabrio Dryer moisture sensor not working
The moisture sensor may be contaminated with softener residue. The residue can be removed with window cleaner ONLY.
Feb 01, 2018 | Dryers
Whirlpool duet dryer - when using the settings that automatically sense if the clothing is dry the dryer is saying the clothes are dry but the clothing is still damp
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Clothes not getting dried
Are you sure that the duct is clean and free flowing? If the duct is partially blocked the dryer's efficiency drops dramatically. I would double check the duct at both ends and clean out as required - air flow is very important - with the dryer on - go check the air coming out of he duct outside - if it is very forceful - then the problem is elsewhere - however if only a little bit of sir is coming out - your all plugged up!.
Nov 19, 2008 | Kenmore 63942 Dryer
Damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
May 02, 2008 | Whirlpool LER6636PW Electric Dryer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Whirlpool LER6636PW Electric Dryer Logo
13,492 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
