We have the phones set to ring but neither one will - they just light up
I had the same problem and it persisted for a few days. Once i sat down and found the manual at ge's home electronics website, the problem was resolved. This is a little embarasing because it's quite an easy fix. my phone handset was displaying a musical note with a line through it. This is to show that the "Do Not Disturb" function is enabled. There is an illuminated button on the base that says do not disturbe.... i hit the button and the ringer works again. If you had the same problem, you are not alone my friend. Time to double our ginko intake for the day. *laugh*
SOURCE: I have a GE model 28213 DECT 6.0 home phone that I
I have a GE model 28112EE2-A DECT 6.0 with a similiar problem. I have had it for over a year and sometimes it won't ring but it flashes. What I did was unplugged the power for about 20 seconds and plugged it back in. Then it was fine. Hope that helps.
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
We suddenly have the same problem. We have had this phone for about 2 years and all of a sudden the handsets won't ring. Does anyone have a solution?
Same problem!
same problem. Arg. I tried adjusting the ringer volume through the phone--it's set on high.
I'm having the same problem.
We have only had our phone for two weeks and it is doing the same thing. It won't ring in but you can call out and you can call in but the ringer stopped working. It is turned on and the volume is set to high.
Same problem here...anyone know how to fix it?
same problem. this phone can lick my balls.
