The knobs on my stoves range cooker keep being distorted by heat is this normal or has the newer cookers been modified to stop this happening, I have replaced the knobs three times while I have owned this cooker over the last 9 years.
SOURCE: Low Gas Pressure on Smeg Range cooker
there should be a regulator on back of the stove where the gas line connects.you will see a plug that unscrews,remove this plug and run the unit.if this solves your problem clean the plug really good and put back on.
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
SOURCE: Vollrath induction cooker is not working. The display reads F9. Model # is 59500.
The range does not recognize the pan material. Only ferrous (magnetic) cookware will work with induction. This is a protection circuit to only heat proper cookware. When all else fails read the instruction book or call the service department for the manufacturer...save time, reduces frustration and assures safe operation. Good Luck
SOURCE: Can't find parts for Lofra range cooker
Hi
lofra mod mxud66ggl
cod -51190118,
type m.ud66ny.
Replacement parts for the top oven door seals .
Regards ,
derek
