My projector turns on, the green light comes on and the red lamp light is on. the fan starts runnin and a dim light comes on and go,s off straight away, and the fan runs for about 2mins and the green light comes back on to ready, wat is the problem hav u guys got any idea,, help me plz,
SOURCE: USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
SOURCE: Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
SOURCE: overheat reset switch for Sanyo PLC-Z4 projector
check the other questions on this topic, I just posted a detailed answer, and that was based on another's answer.
SOURCE: Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
SOURCE: Sanyo PRO xtraX Multimedia Projector Mod.# PLC-XP1ONA
this is the normal condition> only when green led is off and warning temp led(yellow) is on something is wrong!!
