Computers & Internet Logo
Anonymous Posted on Apr 29, 2012
My LG Flatron W1934S screen is now blank - the power light is blinking on and off, but no picture.
  • Anonymous Apr 29, 2012
    Thanks for the resonse, but i plugged LG monitor into my lap top and monitor still did not work. Screen on laptop is fine. I purchased another monitor that works fine as well
Davit Mamyan
Level 3:
  • Master 552 Answers
  • Posted on Apr 29, 2012
Davit Mamyan
Master
Level 3:
Answers
552
Questions
0
Helped
102782
Points
1896
There is no problem with monitor, there is no signal from your VGA card, looking for a problem in your case.
5 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jun 15, 2010
SOURCE: hi everyone , ive got a LG Flatron monitor model
Check out for bad caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Anonymous
  • 32281 Answers
  • Posted on Oct 02, 2009
SOURCE: Lg Flatron W1934S Moniter Problems
You could have a faulty inverter board or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp and the CCFL lamp is a mini fluro tube.
Have a look at LCD Patrs WEB site for service, parts and DIY info Use this link to their WEB site :-
www.lcdparts.net
Anonymous
  • 2985 Answers
  • Posted on May 26, 2007
SOURCE: LG Flatron LCD Power Saving Mode
Well thats seems tricky does it not come on at all when you boot the computer. If the screen is working then it should work to display the Start up screen. If it does then keep pressing Delete until the BIOS comes up- then search the pages for power saving and slect to OFF
Anonymous
  • Posted on May 29, 2009
SOURCE: No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
Anonymous
  • 53 Answers
  • Posted on Sep 06, 2009
SOURCE: Flatron W1934S screen has suddenly started to go bright pink
clean the graphics card first
2helpful
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
LG W1934S-BN Monitor has a blank screen and power LED keeps blinking?
This is usually a sign that the controller for the mini florescent bulbs went out. but try it on another computer maybe its your video card.
Hello, I have a LG Flatron W1934S screen. When I switch on my computer the screen comes up blue light at switch but then turns yellow and with "digital power saving mode" screen goes blank. The...
Try it with another PC first just to be sure it is not video card problem.
More likely that it has dying power supply due to bad caps with leaking/bulging tops a shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/LG%20W1934S/
You should replace them in a set.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
My lg t705sh monitor start after 45 minites of the power on
i am also having the same model,but mine was just power light blinking and screen is blank even not starting after long hours.
My LG flatron monitor just blinking from wide screen then to a smaller screen then it stops for a while then after 5 minutes its gone my monitor doest show or the power does'nt show even if I keep on...
Hi it could be the video card in your computer is going bad slowly or your monitor has a faulty,you should try connect a different monitor to see if the problem id still there if still there this mean the video card is going bad
6helpful
Hi everyone , ive got a LG Flatron monitor model number W1934S the problem im having with it is i keep getting a black screen with the power light still on, but if i unplug the monitor lead and plug in...
1helpful
2answers
2helpful
www.lcdparts.net
Grand Canyon Tech
Grand Canyon Tech
