How do I take off the panel inside the tub? Does it pull off or unscrew?
Pull off all three knobs and then the plastic graphic rings and you will find 2 screws under each. After removing the screws the whole plate can pop off. If your problem is anything like mine, your air pump is full of water and needs to be replaced. After removing all the screws you can carefully pry it up with a thin tool, it is most likely caulked to the tub. You can find replacement parts and names for it here:
http://www.guillens.com/index.jsp?path=product&part=124772&ds=dept&process=search&text=JAC%20%20G107XXX
Hope that helps
Great information and I just had the same issue... after removing and testing switch, I removed the access to find the power source. NO POWER!!! Went to the fuse box and found out there was a GFCI switch in the laundry room (clear across the house) that controlled the Jacuzzi tub and an clothes iron outlet. Voila! Power and all works. May want to check power early on before dismantling anything.
SOURCE: My jacuzzi bathtub plastics pipes underneath are
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
SOURCE: "Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
There are two things you can check, there is a tranformer that plugs into the main circuit board(usually a four wire plug). Unplug and check pins for good connection and then reconnect There are usually one or two fuses inside the control box mounted on or near the circuit board. Turn off power to spa and pull fuses and check continunity. This is a good start.
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
SOURCE: I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
The center button is so amazingly hard to depress and it is very slow to return.
There is no way to unscrew the button from the underside of the tub, so my questions is how do I remove the panel from the tub side? Do I pull on it, hoping it doesn't break or is there something that unscrews? Thanks, for any help.
