Motorola Mobility RAZR V3 Logo
Posted on Apr 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you import phone numbers from old phone to new phone
phoenix kirkham
Level 3:
  • Motorola Mob... Master 641 Answers
  • Posted on Aug 12, 2012
phoenix kirkham
Level 3:
Answers
641
Questions
Helped
112353
Points
1352
Use motorola phone tools
1helpful
How do I export contacts to new phone
What kind of phones are they? If you're switching from your old iPhone to the new one, you can simply transfer contacts with the help of iTunes. You are able to make a backup for your old iPhone and then restore the new iPhone with iTunes. After restoring the new iPhone, you'll get contacts in new iPhone.
  1. Start iTunes, go to "Edit > Preferences > Devices", and check "Prevent iPods, iPhones and iPads from syncing automatically".
  2. Plug old iPhone into computer via the USB cable. Click "File > Device > Backup iPhone", and then iTunes will start to make a backup for your iPhone automatically.
  3. Connect new iPhone to computer with the USB cable, and choose "File > Device > Restore from Backup". Then pick up the backup of your old iPhone, and click "Restore".
  4. iTunes will make a confirmation again, and you need to click "Restore" in the dialog. Then iTunes will start to restore your new phone with the backup of the old one.
After the restoring process, you will get the contents in the backup restored to your new iPhone. In this way, you are able to transfer contacts from old iPhone to new iPhone, and you will also get other data you may want to keep in your new device.
http://www.leawo.org/tutorial/how-to-transfer-contacts-from-iphone-3gs-to-iphone-5.html
Oct 25, 2016 • Cell Phones
How do I set up contact numbers
Go to contact settings then click IMPORT/EXPORT select export to SD on your old phone
Then copy that vcf file to your new phone and click on it that's it
Oct 18, 2016 • Cell Phones
How do I transfer all my contacts from my old tracfone to my new tracfone?
if it has an SD card export your contacts to SD card then put another phone and import them
Jul 02, 2016 • Cell Phones
How do i transfer numbers over from old phone to xperia u st25i?
It depends on the model/make of the phone you have before, but you have a couple of options.
In your contacts, there should be a setting to back-up your contacts. From here, you'll need to choose to back them up to the device or the sim card. If you back-up to the sim card, it will probably limit the number of contacts you can save.
If the old phone is an Android device, you can select to back your contacts up to your google account, after which point, you can relog into your google account on the new phone and the contacts should automatically be synced with the new device.
If you do restore from a sim card, on the new phone, put the sim card into the phone, then go to your settings, within contacts, and import contacts from sim.
So, from the old phone "Export contacts to sim" and on the new phone "Import contacts from sim."
I am charging my phone via a usb cable and would like to import all the numbers on to my comp via blue tooth then port them into my new phone.. how do i do this?
If your new and old phone are from the same brand/manufacturer, you should be able to transfer your numbers/contacts to the new phone using the software that came with your phone. If they are from different manufacturers, the only way to go about it is by synching your old phone to your outlook, then synch your microsoft outlook with your new phone.
1helpful
I have just got a new htc Desire, on the 3 network. I need to copy my numbers from my old Nokia 6300, on Tesco network. Any ideas how this can be done?
On your old Nokia: 1.) Insert your new sim card into the Nokia, and start the phone. 2.) Go to your contact list. 3.) From the option list select "mark all". 4.) From the options list select "copy" then "to sim". 5.) Wait for it to complete, then power off the phone.
On your HTC Desire: 1.) Insert the new sim card (which was just in the Nokia) and power the phone on. 2.) Go to the "People" app. 3.) Press the "menu" button. 4.) Select "Import/Export". 5.) Select "Import from SIM card". 6.) Wait for it to finish the import. 7.) All your contacts have not been copied from one phone to the other.
Sim card not warking
Have you rung your service provider and activated your sim card? It is important to have the phone turned off while doing this. If you haven't changed your number, turn the old phone off too (just in case), and ring them to activate your new sim. You have not posted whether you are using your old or new sim, but judging by the other people with the same problem, this sounds like the case. They will want the serial number off the back of the sim card to do this.
46helpful
13answers
Cannot import contact from sim card to iphone 3G
Turn off the iPhone before inserting the sim, insert sim, turn on, import contacts. If you put the sim in the phone without restarting it for some reason it doesn't get all the contacts sometimes.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
