Frigidaire GLGQ2152ES Gas Dryer Logo
Posted on Nov 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Auto stop problem.
After completion of any cycle, the timer beeps, but machine keeps running with message "dn". Machine stops only after pressing "cancel" button.
Anonymous
Level 3:
Genius:
  • Master 1,028 Answers
  • Posted on Nov 18, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1028
Questions
Helped
316557
Points
2631
Ck to see if wrinkle guard or some such feature is activated ..most dryers have a cool down followed by intermittant tumble without heat to reduce wrinkles
The washing machine completed its cycle and beeped. When I went to get the clothes out, water was pouring in the front of the washer.
If older mechanical/timer control then likely timer. Could be water valve assembly or other. How do you get water stop? What's the make/model of machine?
1helpful
2answers
Programme runs ok but once it reaches 1 minute remaining, the machine keeps on going & does not finish the cycle.
David it sounds like a timer problem, if newer machine the timer may be part of the board, which will have to be checked by a tech for repair or replacement.
Pr5 message is displayed
the electronic program is corrupt. just use an alternative setting.
2helpful
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Washer stalls mid-cycle and keeps running but doesn't progress
check to see if the water is warm if not the heater has gone or the thermistor is faulty
if warm i can be a dead spot on the timer where the contacts are worn if so needs new timer
17helpful
2answers
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Will not Complete a Wash Cycle
hello.
Please consider examine the control panel and the circuit of the machine maybe some connection setting is lessen.
melnavz
Mar 18, 2008 • Dishwashers
End of Cycle signal keeps beeping
Try pressing "rinse" + "pre-wash" buttons together for over 5 seconds. It will lock. Repeat again for 5 seconds, it will unlock.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
