PNY 1GB microSD Memory Card Logo
Posted on Nov 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Load music to my Micro SD
I tried to load music to my 1gb microSD and my computer keeps saying insert a new disc because of a copyright.
Anonymous
Level 2:
  • Expert 62 Answers
  • Posted on Jan 19, 2009
Anonymous
Expert
Level 2:
Answers
62
Questions
0
Helped
14570
Points
141
Thats not a copysight isssue i think you have a virus problem ot tey changing the usb port because speed of data transfer may also be the problem
How to reset the password memory card
Transcend??
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab.
Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
or
Slide the switch on the left-hand side of the SD card. If the switch is broken, proceed to Step 2.
Affix a small piece of tape or paper to the top half of the gap where the slider should be. Do not permanently affix the paper as of yet. 3
Try the card in your computer, using the USB converter stick.
If the items on the SD card are available, copy them to your computer as a precaution.
If that did not solve the problem, proceed to Step 4. 4
Remove the tape or paper and reattach it to the other side of the gap if you mistakenly attached it to the wrong side.
If you are actually trying to unlock a micro or mini SD card, proceed to Step 5. 5
Toggle the switch on the left side of your SD Adapter if you are trying to unlock a micro or mini SD card.
Micro and mini cards do not have switches.
Instead, insert a micro or mini card into an unlocked SD Adapter to work with stored data.
SD Adapters look very much like SD cards and the switch works the same way.
I want to download a music to my microsd
insert you memory card to computer, use card reader
at computer open windows explorer
chose the music that you want to download to micro sd
then right click chose copy
go to micro sd drive then right click then chose paste
done
Computer isnt recognizing micro sd but cell phone does. I'd like to transfer mp3 files from computer onto cell with microsd
leave the sd micro in cell and connect the cell via usb to pc/laptop..go to my computer on pc you should see a new drive yes the cell card copy/paste or click/drag your mp3 files to cell from your music folder
Micro sd
Please try to insert it into another computer if the same error prevails uou have to replace your micro sd its bad.
I have a sd micro card and i want to load music on it from my computer to put on my phone
This is a relatively easy problem.
You can do so by using a memory card reader.
You can easily get a memory card reader from any local store at a cheap price, depending on your country.
Most of the Memory card readers come in USB type, so what you just need to do is to plug it in any available usb port on your PC, and then insert your
sd micro card in the appropriate port for it.
For SD Micro Cards (The Smallest Types), most times you might need to first insert it in a Small Card Adapter that comes with SD Micro cards, before inserting it in your USB Card Reader.
Hope this helps you out.
Kindly let me know how it goes.
Good luck.
2answers
Sandisk micro sd gb1 help finding music
try using a program called recova or another file recovery program or if your files are still there but "hidden" click on view (windows 8 and up) and click hidden items (if that doesnt help let me know)
Sandisk micro sd card 1gb(SDSDQ-1024-A11MK)
when u connect ur fone, a memory card ll appear in MY COMPUTER
if it does not try installing the cd u got
otherwise some driver problem
1helpful
3answers
Micro sd 4gb micro card.
Guaranteed solution!
This is from Duracell Support
Unfortunately, we have found an incompatibility with a new revision of our microSD and the USB adapter that accompanied the card you purchased. We are in the process of solving the compatibility issue. We are truly sorry for the inconvenience and would like to send a new card that is compatible with your USB adapter. Your original card should be functional in other adapters, phones, and cameras. The microSD card's compatibility problem should only exist with that USB Adapter. For your inconvenience, there will be no need to ship the original microSD card back to us so feel free to keep and use them both. We would also like to send you two free music downloads from Duracell Flash Memory.
If you would like to take advantage of this offer, please let us know your full name, address, the size of the microSD, and the name and location of the store from which you purchased your microSD. When we receive your information we will ship your replacements parts and music downloads immediately.
Best Regards,
Duracell Flash Support Team
Here is how to reach them:
http://support.duracellflash.com/ics/support/default.asp?deptID=5612&ticketID=7688933
Saving music on my micro sd..
well assuming you loaded music on your sd card:
to find it, just go to mystuff....
menu, mystuff, center button, it should load the mini sd right there. then all you have to do is click over right and file explore the mini sd. you should put music in the music file.
another option on the phone.....
go to att music
menu, upper left icon, center button, music player, it should find all files.
let me know how i can help some more
Top PNY Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
