Televison & Video Logo
Posted on Nov 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DVD recorder/HVS combi - failure to complete self-check
Machine is just over 1 year old. No problems until recently. DVD recorder flashes 'hello' then error message U61, then 'hello' again. on TV screen I get message re failure to complete self-check.On pressing 'Enter' machine goes off. This has happened a few times - sometimes if I leave it off at the mains for a few hours it seems to self correct, but it is happening more frequently, and now very irritating as I obviously cannot record or play anything when it happens. Sometimes I just get 'Please wait' flashing for hours - unresponsive to anything until I switch off at mains. Any help would be much appreciated.
  • 2 more comments
  • ab74 Nov 17, 2008
    Sorry - I thought I had - it is a Panasonic DMR EX95VEBS
  • ab74 Nov 17, 2008
    I've checked the wiring and tried changing to different electrical socket - same problem with DMR EX95VEBS occurs. This time after the 'Hello' and U61, when I press Enter I get DVD1 and then back to 'hello'. The only way to get rid of the on screen message re failure to complete self check was to press the DVD open/close button.
  • ab74 Nov 17, 2008
    The problem at the moment is that the machine won't let me do anything - including opening the disk tray - so I can't use a cleaner.
  • ab74 Nov 18, 2008
    Any more bright ideas welcomed - machine now flashes DVD1 when any button is pressed, then returns to either 'Hello' or 'Bye' and goes off again. I just want to know if it is worth trying to get it repaired, or junk it and start again. As it is only a year old and expensive, I'm reluctant to do the latter.
Anonymous
Level 3:
  • Master 685 Answers
  • Posted on Nov 18, 2008
Anonymous
Master
Level 3:
Answers
685
Questions
Helped
229797
Points
1828
Try unplugging it for a while and then plugging it back in
Anonymous
Level 3:
President:
  • Master 624 Answers
  • Posted on Nov 17, 2008
Anonymous
Master
Level 3:
President:
Answers
624
Questions
6
Helped
278233
Points
2008
Since the problems are intermittent that indicates that the soldering on one or more of the boards will need to be reflowed. I have repaired a few of these models and on more than one occasion with this error the microprocessor needed the solder reflowed. This is not a job for anybody without the very best soldering skills. The micro is a surface mounted flat pack IC with pins on all four sides, a total of 80 pins if I remember correctly. If the reflowing of the solder is not done perfectly the unit will become dead.
Ever since the manufacturers started using the "lead free" solder, we have been seeing many more cases of problems that are caused by bad solder connections. It seems that this new "lead free" solder just doesn't hold up to the heating and cooling stress nearly as well as the solder with lead in it.
Unless you have extensive soldering experience and a good familiarity with electronics, you really should just take it in for service, there will be nothing that you can do to fix it on a permanent basis, only short term fixes by unplugging it for a day, then it may work for a day or two, but the problem will still come back again.
Anonymous
Level 3:
  • Master 734 Answers
Anonymous
Master
Level 3:
Answers
734
Questions
Helped
350314
Points
1732
Here is what you have to do unscrew the cover 4 large screws 2 on each side 3 smaller screws on the back cover lift cover off you should see disc reader with 4 very small screws take them off now you should be able to see inside where the disc is read.it could be that the reader is forward push it back it may be the open and close tray is stuck force it to open gently all the time hitting the reset button just play with it .it should free it up but remember gently
  • 1 more comment
  • Anonymous Nov 17, 2008
    procedure 2:::
    cleaning the black spool that retains and spins the disc. Using denatured alcohol on a lint free cloth, I carefully cleaned the hub but did not saturate the material. This immediately cleared the no read and unable to record errors. Of course, I had to remove the outside covers to access the inter-workings of the read-writer.
    procedure 1: please try them first----
    For U61 errors:Turn unit off
    flip down front a/v input panel
    simultaneously press the channel up and stop buttons for at least 10 seconds.
    finaly if you dont find the solution then go to ---- there is all about Err u61 ---
    http://jacobshome.blogspot.com/2008/02/p...
    THANKS
Anonymous
Level 2:
  • Expert 94 Answers
Anonymous
Expert
Level 2:
Answers
94
Questions
0
Helped
21448
Points
259
It usually shows that there is a problem with one of the internal voltage rails.. It might be the capacitor. I tried to look for instructions on how you can replace your capacitor but this is too risky. You may need to send the DMR for servicing.
Anonymous
Level 2:
Scholar:
  • Expert 126 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
126
Questions
0
Helped
28698
Points
311
Hello ab74,
I have seen this problem in the past with this model of machine. It seems to be a power supply issue, mainly the electrolytic capacitor. You can unplug the power cord and wait for a few minutes and this should clear the error. However, I beleive you will get the error back after awhile as the power supply is experiencing what is know as leakage. Hope this helps.
Lee Hodgson
Level 3:
  • Televison & ... Master 4,810 Answers
Lee Hodgson
Level 3:
Answers
4810
Questions
Helped
1782720
Points
15941
Have a look in the user manual to see what the error code means, if its not in the manual, phone customer support help line to see if they can instruct you on what to do, there maybe a factory reset code that has to be inputted by the remote control, check to see if there is a firmware update for DVD because it is most likely this.
Another thing (providing its out of warranty) is to open it up and clean the inside free of dust.
If it is still in warranty send it back! Or turn it off from the mains and leave it off for at least 24 hours
hope this helps
regards
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3090174
Points
19604
For more specific diagnosis, brand and model would be required. Initially though, normal suspects for similar products would be dirty/weak laser/lens and could be cleaned with a CD cleaning disc. Another common problem is the spindle motor or the guide rail for the lens carriage which could lead to mechanical problem.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Anonymous Nov 18, 2008
    Appreciate the additional information.
    It would seem that the error is mechanical in nature, traverse problem. Simply stated, the carriage of the laser eye could not move to its designated park position. This is part of the self-check on startup. After cleaning, a general purpose light lubricant should be used. Solution proposed would be cleaning the mechanical components with special attention to the guide rail. In some remote instances, it could also be the motor that drives the carriage back and forth along the railing. Pls reference this post for added insights on spindle/small motor repair. image below maybe used as reference.
    Cheers.
Anonymous
Level 3:
Brigadier General:
  • Master 3,614 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
3614
Questions
24
Helped
1009605
Points
10054
First kindly provide the exact model / maker of your TV.
try checking all possible loose or wrong connection on the device. unplug and plug the tv set into different electrical outlet.
4helpful
My recorder wont record on new discs
Daewoo DVD Recorder/VCR combi (I believe the model number is DF-4100P it wont record on disc but it will on tape mode plus the drawer in the dvd wont open please can someone send me an answer of whats wrong with it thank you
1helpful
The Samsung DVD recorder does not record. Is it cheaper to repair or cheaper to buy another? This combi is approx 2 years old.
I would say for a 2 years old set, its better to buy a new one than repairing it as new one is far more cheaper. DVD recorders are becoming more and more cheaper as BLURAY recorders already hit the market. My advice, get a new one and dump the old one. You will get 1 year warranty too for buying the new one. If u repair the old one, there's no guarantee that it wont get spoiled again.
Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
2answers
Recorder records for approx 1 min the self checks
are you using dvd r or dvd rw discs ?? the r disc cause less of a hassle i have been told hope this helps regards Jim
Lite On disc writing failure
try updating the rom by downloading from lite-0n
6helpful
My recorder says "full" when i try to record, but i have deleted everything!!??!!
Solution for this problem is to Format the recorder. Step 1 is to turn on unit. Step 2 Press Erase " Delete will flash on the display. Step 3 Press and hold Rec for 3 seconds "Format" will flash on the display. Step 4 Press and hold Erase, the completed percentage will show on the display (formatting is now in progress). Step 5 After formatting is completed the remaining time will show on the display. You should now be able to record. Make sure that you hold the ERASE button in step 4 until Formatting shows 100% complete.
Panasonic dvd recorder
Hello again Dan
I repair these, but I have not seen this particular fault before.
However, you mention that you used to be able to leave it for an hour and it would then work. This means the unit was having difficulty in initialising.
There is a very common fault with this model where a power board regulator overheats and fails. This causes the machine to go into a self checking cycle. It will say "Self Check" on the display and if you leave it, the machine will often eventually work.
The regulator fails from about two years onwards, with various symptoms gradually getting worse until the unit packs up completely.
I can send you the full repair details if you want them, but you would have to be able to use a soldering iron and be confident in your own ability to disassemble and tackle a job like this. Or you may know someone who could repair it, if given the full details.
It should be an easy fix, so it would be a pity to write it off for such a fault.
Best wishes...
2answers
DVD Recorder stuck on "loading"
That's exactly the same problem as I have, any suggestions would be greatly appreciated. Used to solve it by turning off at the plug and restarting. Now won't load up at all though. I love the machine - when it works - it just isn't very often!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
