Hi,here it is some tech info and the user ratings from Amazon...it is a fair price for 2.hand...as ebay has the similar prices..it seems to be a good deal...
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!----------------
Product Features and Technical Details
- Dolby Digital, Dolby Pro Logic II, and DTS-decoding home theater receiver with 5 speakers and a powered subwoofer
- 35 watts per channel x 4 "tallboy" speakers, 140 watts for the center channel, and 150 watts for the subwoofer
- High-resolution DVD-Audio playback; JPEG, MP3, and WMA CD playback
- Magnetic shielding for distortion-free placement near a TV or computer monitor
- Includes digital FM/AM tuner and a universal remote control
Technical Details
- Brand Name: Panasonic
- Model: SC-HT900
- Output Wattage: 390
- Component Type: Home theater system
- Audio Output Mode: Surround Sound
- Surround Sound Effects: Super Surround Sound
- DVD Type: DVD changer
- Built In Decoder: Dolby Pro Logic II, Dolby Digital, DTS decoder
- Remote Control Description: Universal remote control
- Optical Digital Input: Yes
- Audio Input: None
- Tuner Technology: Digital
- Radio Bands Supported: AM/FM
Panasonic SC-HT900 Home Theater System with 5-Disc DVD Changer
Very attractive system with many features. Progressive scan DVD player
looks great on my projector, thanks to the high end video circuitry in
the 5 Disc DVD changer. Sound is very clear and accurately reproduced
though the six speakers. Movie dialogue comes through very naturally.
Does a fine job at decoding Dolby Surround. Movie "bass" effects are
clear and pronounced through the active subwoofer. I've tested this
system in store next to an expensive Bose and the quality is more or
less comparable. It is a known fact Panasonic DVD players are among
the best in the business. Many more expensive DVD players(costing
considerably more than this system) made by other brands use Panasonic
internals for their players.
All DVD players must contain an MPEG
decoder. In addition, progressive scan DVDs must contain a special
device called a deinterlacer. Interlaced video frames are sent to a
television in two pieces, by first drawing all of the odd lines, then
the even ones. The deinterlacer essentially doubles each frame of
video(producing a very defined picture) by filling in missing
information. That is the true meaning of "progressive scan." This is the
basis for HDTV, and be aware that your (Projector,TV,LCD) must be able
to display HDTV or progressive to take advantage of this great feature.
As with any other product, deinterlacers vary in quality and must be
able to handle various film encodings. Panasonic uses top notch internal
hardware to perform the deinterlacing(DCDi) and decoding. The results
are spectacular!
Don't expect the bass to blow your ears out - no
system at or near this pricepoint will. The subwoofer is powered but yet
conservative (but more than other systems in its class). Don't buy
this unit to play at maximum volume. System can be cranked up to loud
but not extreme voulme. Sound will be more than enough for rooms This unit also makes a
great system for listening to FM Radio, CD/R etc. Unit supports many
types of Discs. Music seems rich and pleasing, in some cases exceeding
much more expensive units.
The speaker stands will save you the
cost of buying wall mounts. This system has a plethora of features that
are stated in the manual. For example, there are multiple surround
modes, seating placement adjustments and digital input capability.
Unfortunately the owners manual is written like an engineering course
lab manual - so it may take the non- technical some time to learn all of
the arcane features. Also, you should purchase at least a 16 gauge
spool of speaker wire - do not use the doorbell wire that is supplied
with the unit.
Overall I will give this unit 5 stars, because it
is priced very well with respect to its competition (Sony Dream system
990) and it exceeds that and other products in its class in terms of
quality and features. On the other hand, if you desire a very loud,
extreme bass systems - don't consider a home theatre in a box. Purchase a
component receiver/amp with large poweful speakers. And of course, a
Panasonic progressive DVD player for the best video!
Thanks for the help but.....
I am having no trouble getting video from the DVD player, the issue is sound only.
The DVD player has 2 connections for video, 1 coax and 1 S cable. I used the coax direct to the TV and it works fine.
For audio the DVD player has the red & white stereo connections, and a coax cable connection. I plugged the coax cable connection to the receiver, but get no sound, with the receiver set to DVD coax signal. The only way to get sound is to use the stereo connections and plug in to the VCR red & white connections on the receiver.
Of course the TV is set to the correct source, but that wouldn't affect the audio anyway.
If the receiver had the red & white connections to the DVD player I wouldn't have a problem, but it only has the single coax cable for audio to the receiver.
Now we're on the right track!!!
I went into the setup menu on the DVD player, and after much searching around went to the Audio setup screen where it had a menu for audio output source type. It was set for SPDIF/OFF. The other choices were SPDIF/RAW and SPDIF/PCM. There was no mention of Dolby digital anywhere in any of the menus. When I selected either of the other two choices, the surround sound works perfectly. There is no explanation of any of these selections, so I left it on RAW for the time being.
I then hooked up the VCR for the first time, and it worked perfectly in stereo as I had expected. It will also allow me to play TV program audio while the receiver is set for VCR.
However when set to TV I still can't get TV audio directly from the TV directly to the receiver (without being modulated by the VCR first). If unsolvable (perhaps due to the age and model of my TV) I can certainly live with playing TV through the VCR if I have to. I won't replace the TV till it fails, and it has been totally trouble free for 11 years, and is still awesomely clear and sharp, rivalling much newer technology.
Okay, I have everything working now, you guys got me on the right track. I got the TV working now as well by going into the TV setup menu and trying the different options till the receiver fired up. Have to turn my TV speakers off in setup each time unless I want to use the receiver all the time. Again fairly minor.
I am still curious about the RAW setting on the DVD oputput.
Thanks a bunch guys...I wish I could remember the name of the lady who put me on the right track of checking the setup on the DVD player and not blaming the receiver. It's all working fine now.
