Computers & Internet Logo
Anonymous Posted on Apr 27, 2012
I can't find how to adjust the brightness of my screen in Window Xp on an MSI laptop
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Apr 28, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1059439
Points
15385
Press and Hold the FN function key located near the bottom left on the keyboard then hit the key that adjusts the brightness.It will be one key for brighter and one key for darker. Look for the keys they will have the icon of a round sun or washer looking circle with the up or down arrow on it.
  • Anonymous Apr 30, 2012
    It worked! Thanks! Appreciate the help of this team
3 Related Answers
Anonymous
  • 221 Answers
  • Posted on Apr 17, 2009
SOURCE: how do i adjust the screen brightness
To adjust screen brightness on a laptop press the Fn key at the lower left of the keyboard and then press the arrow key's at the lower right of the keyboard.
Anonymous
  • 83 Answers
  • Posted on May 25, 2010
SOURCE: How do I adjust the screen brightness on a HP
Hi, Actually, the problem here is you don?t have any options in windows XP to increase the brightness without using keyboard. HP does not provide any utility with the OS as it is OEM. Try this · Click on start > Click on control panel..... · Click on power options.... · Click on " Change settings plan "..... · Adjust the brightness and save the plan..... And exit... that should work.... OR Replace the keyboard and get the all things working
fredcapra
fred capra
  • 85 Answers
  • Posted on May 29, 2011
SOURCE: My laptop is Sony vaio vpcs111fm with OS of window
Go to the Sony web site. Go to support, and download drivers for the hotkeys. It sounds like the upgrade did not pick up all of the OEM features.
Brighten laptop screen
Down button right hand side there is a battery sign with charging click on that.
Click on ADJUST SCREEN BRIGHTNESS
Down you see SCREEN BRIGHTNESS (written now you can increase and decrease the brightness)
Or
Go to control panel
window vista:- CLick on left hand side CLASSIC VIEW
Window 7:- in address bar click and sellect ALL CONTROL PANEL ITEMS
Now click on POWER OPTIONS
AOC monitor too bright!!!
Sounds like its T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD is given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1helpful
I have a hard time seeing my screen in XP - where do I go to adjust the brightness of the screen
How hard a time is it? Maybe your screen is going bad or the LCD Inverter is bad.
Press and Hold the FN function key located at the lower left portion of the keyboard then hit the key that makes the display brighter or darker. There will be one key for brightness and one key for darker. Normally it will have the icon of a sun or washer with the up or down arrow.
Brightness adjust
You could buy a laptop LCD cover to make the screen darker.
Is the MSI 945GCM5-F 7.1 motherboard on-board graphic card compatible with LG Flatron wide screen? Up until now we had a GF card, but now it's gone, and using only the MSI we don't seem to be...
Hi
You don't say how big the screen is, what connectors it has [VGA (Analogue), DVI (Digital) or HD (High Definition)] or which Operating System you're using.
Right click on open space on your desktop.
Properties > Settings (XP)
or
Personalize > Settings (Vista, Win 7)
Left click & hold on the slider and slide to adjust resolution.
You are given the option to test and accept each setting change you make.
When satisfied, Apply > Yes > Ok. Then restart the computer.
If your screen is large and has Digital and/or HD capability and the above advice does not help you find a resolution setting thast completely satisfies you, you may need to consider a dedicated PCI-Express Graphics Card to upgrade your graphics performance and give you a wider range of resolution options.
Hope this helps.
How do i adjust brightness in hp g60
Here's how to adjust the screen brightness for a laptop in Windows 7:
  1. Go to Control Panel -> Hardware and Sound -> Power Options.
  2. Click on "Change plan settings" for your laptop's selected power plan (either Balanced or Power saver).
  3. Now edit your plan settings by moving the sliders next to "Adjust plan brightness" at the bottom. You'll be able to change the brightness for when your laptop is On battery power, or when it's Plugged in.
  4. Once you've adjusting the brightness settings to your liking, then click on the 'Save changes' button.
Alternatively, here is another way: From the Windows desktop, hold the fn key and press the f7 key c00776226.jpg to increase or the f8key c00776225.jpg to decrease the brightness of the display. If using the function keys does not resolve the problem and you have a Lid Actuator on your particular model, check the movement of the Lid Actuator switch to determine that it moves freely and is not stuck. NOTE: The key numbers (f7 or f8 ) may vary depending on the notebook PC; however, the images on the keys should be similiar. If you reboot the PC after using the function keys to change the LCD brightness settings, the brightness may return to the default setting on some models, which is based on the power source-battery or AC. This is not an error. The notebook is functioning as designed. If the notebook returns to the default setting after rebooting on your particular model, use the function keys to change the brightness back to the desired settings.
My laptop display very dim
If your HP laptop has a dull screen, or if the screen is too bright to make out anything that's displayed, you may need to adjust the brightness to get your screen back the way you like it. You don't want to strain your eyes to see your screen, and the fix is really simple. It's about as easy as adjusting the brightness on a TV. You'll have your brightness set the way you want it in a few seconds.
1. Right-click on an empty space on the desktop and a drop-down menu will appear.
2. Click on "Properties." If the HP laptop uses Windows Vista, you'll click on "Personalize."
3. On the "Personalize appearance and sounds" screen, click on "Window Color and Appearance."
4. Click on the arrow beside "Show color mixer."
5. Use your mouse pointer to move the tab on the "Brightness" scale to the left or the right to adjust the brightness and click on "OK" when you're content with the color.
I hope you find it very helpful. Thank you for using fixya.
Best regards.
9helpful
4answers
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
2answers
Screen is very dark on my dell m20 after re-installing windows xp, is there some kind of screen driver for the lcd?
it is just probably the brightness settings. to adjust brightness, simply go to control panel, if you are watching folder wiev, where you see all options you have, find the one saying power settings, now there should be, either in the tab to the left, or in the main-window, a link saying adjust brightness, follow that link, and you should be able to adjust your screens brightness. But, if your setting are divided into category wiev, i.e. hardware and sound, user accounts and family setting and so on. Enter the hardware and sound folder, find the power setting link, either in the tab to the left, or in the main-window, when you have, follow the link, called adjust brightness, again, either in the tab to the left, or in the main windows.
2answers
Adjusting Screen Brightness in Windows XP
Brightness is not adjusted within the windows operating system It is adjusted at the monitor.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
