Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby uprigt bagged diamond edition lost it's suction
Has no suction power
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Make sure it has a clean bag and not clogged up
Posted on Feb 20, 2019
SOURCE:
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Posted on Sep 03, 2007
  • 112 Answers
SOURCE: gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Posted on Jan 15, 2008
Agent Don
  • 310 Answers
SOURCE: Manual
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=617575
Manual
Posted by Caroyl on May 23, 2008
Is there a manual I can download online for the
Kirby Ultimate G Series Diamond Edition, Model G7D?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My suggestion is that you contact the Kirby Co in Cleveland listed below and they will instruct you either to down load a owner’s manual or they will mail one out to you, there might be a local Kirby dealer in your area that might have a manual as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 29, 2008
RockyNR1
  • 324 Answers
SOURCE: I have a Kirby Ultimate
See it HERE
Enjoy
Posted on Jan 06, 2009
SOURCE: smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Posted on Feb 24, 2009
I have a Kirby G series diamond edition. There seems to be no suction when I turn on the vaccum. The bag inflates, but the roller does not turn. It has a new belt and the roller brush is clean. Any...
THE IMPELLER LOOKS SHOT.. 25 QUID FOR NEW ONE,,LIFT THE LID AND TURN THE ROUND PIN AND CHECK FOR RIDGES ROUND THE WHITE IMPELLER,,IF NONE THERE THATS IT,, HAPPEND TO ME TEN MINS TO FIX GEORGE
Jun 02, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Where can i dowload a manual for kirby diamond edition vacuum
you can buy the manual on ebay they sell for less then $10 just put kirby diamond owners manual and they should come up
Feb 16, 2011 | Kirby Ultimate G Bagged Upright Vacuum
What is the button on the side of diamond edition
The button is for high speed/low speed or suction.
Mar 10, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Diamond Edition (no power)
You just check the bag "boot" to see if there is something worn down enough to keep the vacuum from turning it back on. If it is worn, buy a new mini-emptor assembly and install it and your vacuum should work fine.
Jan 04, 2009 | Kirby G5 Bagged Upright Vacuum
Take a look at the help article here. If bristles are worn you may need to install the brush roll in a different position (details HERE) or purchase a new brush roll.
Good Luck
Rocky
Jan 03, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Lost my manual
Here is a very important bit of information...how to change the belt! Check out my online guide...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope it helps!
Marci
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Gear lever
Transmission:
On/Off switch
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
172 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
