My sister in law is in France trying to connect a macbookair to a orange livebox will not connect anyone help tried all the common sense solutions
Yes, you need to press button #1 on the livebox , which will put it into 'accepting new wifi devices' mode. This lasts about 1 hour.Presumably you've entered the wep key from the label on the bottom of the livebox into your macbook? don't forget it's got to be UPPERCASE characters!
Testimonial: "thanks"
SOURCE: Orange Parential Control Windows Vista
Use the following link to disable parental control
http://www.howtogeek.com/howto/windows-vista/disable-user-account-control-uac-the-easy-way-on-windows-vista/
The second option you can try is do a system restore, ie take it back to the day it was working fine.
To do the same
Click the start button (pearl) and type system restore in start search.....
choose a restore point when you first installed the software....
Thanks
proton
SOURCE: Wonder if you can help
Yes you can allways share your network connection and let others in the range use it.
if you right click on my network connection go to propertis of the connection and you could have the option share this connection and will be able to share it.
if your service provider has not blocked it.
thanks and regards
Dushyant
