The fan will go on and off but the compressor continues to run and freezes up the unit. The only way to turn off the compressor is to shut off the AC breaker
There has to be a stat or switch or controller of some kind on the rv. I would check that first. If you have a battery operated stat then try changing the batts, otherwise it could be the contactor on the unit or a bad stat.
Im having the exact same issue,I replaced the thermastat and it still runs,have been told its in the board ....thats over 100.00,ho do we test the board??
Have you found out how to fix this problem? I have same problem
My Domestic 2200 runs constantly when connected to mains power even though the unit is turned off! Anyone had the same? problem and found a cure?
