Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
Posted on Nov 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsu DLP 65831 won't power up
This set was working fine till this am. My daughter turned it on an it didn't start. I went over and tried with the same results. Press the power button, light turns green, there is a faint clicking/popping noise, and a fan starts and stops, this goes on for a couple of min and then the set powers off. No message no picture, nothing. I unplugged for a few mins them tried again, same results. Last year I had a problem with a loose wire on a heat sensor by the bulb. This beamed to be a common problem and the fix was to reseat the connecter for the sensor. This time nothing... Any help would be greatly appreciated.
Anonymous
Level 2:
  • Expert 108 Answers
  • Posted on Jan 10, 2009
Anonymous
Expert
Level 2:
Answers
108
Questions
0
Helped
37614
Points
212
Mitsubishi WD-65831 65" DLP Rear Projection TV. Bulb burns out frequently.
Question edited for full 'make model (what it is)'.
Usually overheating or cheap bulbs made in China. $200 bulbs are better than $84 bulbs. Very old technology, time for an upgrade!
https://www.google.com/search?q=Wd+65831
Battery is new, engine won't turn over.
The voltmeter should only go as high as 14-15 volts when the engine is running. I would check for a poor connection between the battery and starter.
Both headlamps won't come on on 06 Touareg. dash light says check headlamps. is it possible that both of them could go out at same time? I'm sure it's quite expensive to repair or replace.
It is very possible you could've running with one burned out for a while and didn't notice uad a power serge or it's possible you have been running with one out for a while and didn't notice till the other went out. Try turning on the high beems if they work replace the bulbs..
1helpful
My car was running fine yesterday and this morning it didn't start. got a new battery, replaced the oil and checked the fuses. everything is fine but car still won't start. suggestions, please
Check for spark and fuel. When you turn the key on you should hear the fuel pump in the tank for a few seconds till the pressure builds up. When you crank the engine there should be spark at the plugs.
I have a 65 inch mitsu DLP, replaced the bulb 6 months ago.. Worked fine until this week.. Now the TV will power up, turn on, then show a picture for a second then go black.. It repeats this nonstop.. ...
Sounds like the Lamp is over temperature. Either the fan went out or the filter is clogged! You might check the filter first. I hope this will help you...
I have a 2005 52 inch Mitsu turn it on and it goes to red light
di you replace the power for the lamp in your manul it will show you the lite set for your tv it it will give you i ideal what wrong. i see so with bad power supply or
the balstor go bad to i chang lamp bastor frist. when
the lamp go bad it will show you it the lamp in front of dlp. i hope this help you out.
I have a 61" samsung dlp. It worked fine
Start with replacing the lamp. Then move on to the Ballast. Then the color wheel. Then the Power Supply. One of those parts should fix it. If not call back.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
