I bought a GE 2.4ghz cordless telephone with answering machine. I can hear the handset ring and the answering machine works fine. I just cant answer my telephone.
It says in the back that i am to press the answerer button then the * and enter my security code then * again but i cant seem to do that either.
HELP and thanks
SOURCE: GE 2.4 GHz cordless telephone problem
Hi there, maybe I can help;
Is the phone base plugged into an switched outlet and is the switch off?
Let me know if I helped
SOURCE: no dial tone
Sounds like you may have a problem with the one handset. Check to see if there is a volume control that you can turn up louder. It may only work while you have the phone in the talk mode. If that doesn't solve the problem then it sounds like the handset is bad. You may also want to plug a headset into the bad phone to see if it will work that way. Providing of course that the handset has a jack to accept a headset. Good luck.
