Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
A
Anonymous Posted on Apr 25, 2012
What spark plug for st155 homelite trimmer - Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Jun 17, 2009
SOURCE: I need spark plug cap for my homelite trimmer
Hello you can oder parts from this website for your trimmer. If you need just a spark plug go to any home depot.
http://www.odref.com/homelite/string-trimmers/
I Hope this helps.
Tobaz
panilling9
panilling9
  • 284 Answers
  • Posted on Jul 05, 2009
SOURCE: spark plug gap
What plug are you currently using?
if its a DJ7Y gap at 0.025 tapered seat
if its a DJ7J gap at 0.030 tapered seat
if its a CJ8 gap at 0.025 gasket
if its aCJ6Y gap at0.030 gasket
if its a CJ6 gap at 0.030 gasket
these are champion plugs
if you have different cross reference your make
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Nov 18, 2009
SOURCE: My Homelite UT-20002A trimmer have a hard starting
If you can, check to make sure there is a spark. Check the plug and notice if there is a presence of gas/oil mix on the plug or in the cylinder. Also, make sure the air filter is clean Try to make sure all bolts and screws are tight as lots of vibrations can loosen some of them.. An air leak on the engine could be causing your problems. A carburetor that is in need of a rebuild will do the same.. Finally an engine that is badly worn and has weak compression will not start, period.
Fahr Quad
  • 776 Answers
  • Posted on Jun 27, 2010
SOURCE: Homelite trimmer UT20832
The gap on my 18 year old Homelite ST-185 is 0.025. Since they are still using simple and reliable magnetos, yours should be the same.
Anonymous
  • 3 Answers
  • Posted on Sep 08, 2010
SOURCE: Trimmers: Homelite Easy Reach-25cc-Model #
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
My homelite trimmer is very hard to start back after used for a while. What is the problem actually?
coil failing when hot or the spark plug same reason
carby fuel vaporizing in combustion cylinder
rings loosing compression due to age of trimmer
Homelite Trimmer Parts
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
4helpful
2answers
MY HOMELITE STRING TRIMMER UT21505 PRIMER BULB LEAKS. MY PARTS LIST DOE'S NOT SHOW THIS PART. CAN I PUCHASE IT OR DO I HAVE TO THROW IT AWAY
You can easily get a new primer bulb for it...most small engine repair shops will have what you need, and if you want, you can most likely snag one on Ebay....DON'T THROW IT AWAY, ok?
2helpful
What is the right size trimming cord for the st 155
On the spool you should be able to find the size. Look for decimal sizes; .065, .080. etc... That will be the correct size...Lee
I need spark plug cap for my homelite trimmer ut2004a
I Hope this helps.
Tobaz
1helpful
Homelite MightyLite 26cc Edger won't start
You have to make sure the case of the plug is making good connection against the metal on motor. Use file or sandpaper to get good connection on the plug and the motor.
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
