Java seems to just connects to pogo games. I am not getting errors it just won't connect. I have installed the new Java program and have tested my computer to see if Java is working fine and it seems to be. I seem to have problems with Pogo games. I have tried the troubleshoot on help in pogo page to no remedy. To give it a nudge to connect I have to use my task manager and give firefox some help to connect. When I use windows explorer I have to use trusted site and manually keep clicking http://game3.pogo.com After a few minutes it seems to connect to the game but this is very frustrating. It's even worse using firefox. I hope I have explained my problem enough for you to understand. I have tried almost everything I can think of. It like a car won't start but tweak it and then it fires up after awhile
Lost in Canada
YOU SHOULD CONTACT POGO SUPPORT HELPLINE AT
(( +1-800-585-2494))
What version of Java do you have installed on your computer?
The newer versions of JAVA (post 1.7.0_14) have restrictive security and may be causing your game not to connect properly.
Go into JAVA management console
Start > Control Panel > Java > Security > Edit Site List > add the server for your pogo game
see if that helps
I CAN NOT GET POGO GAME I HAVE A NEW MACBOOK AIR I HAVE NEW JAVE 7 ] I PUT ON IT PLEASE HELP ME
Try flushing your Java cache.
Start > Control Panel > Java > Temporary Internet Files (Settings) > Delete Files.
You might even try UNchecking "Keep Temporary Files on My Computer".
RDO
Thanks for the help ricky but I already tried that to no advail. Its sad that I have to open task manager to give it a nudge. It seems like it not loading the Java. Anything else I could do? Could it be in my isp settings to unfreeze it?
I hope somebody can help me. I just went out the other day and purchased system mechanic to see if that would help. I thought for sure it would. Nope.
Lost in Canada someplace :)
Thanks again
I have Windows xp. I installed Java to be able to play in Pogo. When I click to play a game it starts loading then I get the message from Java notworking or installed wrong. I did the check Java test through Pogo...all 3 boxes popped up saying everything was installed properly and working and to go play and have fun. Still I get the Java message and no game.
Help ! I am at a loss.
I have the same problem, I uninstalled sun java, reinstalled, rebooted computer deleted temp files in java , and every time go to bingo in pogo games, chat downloads and game doesn't, get error message , went into my fav christian chat and had to close and open window to get in, sun java is not working very well....any suggestions?
I have the same problem with pogo and java and I have tried all the things everyone has told me to do and still not working,Help When I try playing games at pogo.com it says java not installed or not working,I have the newest version of java and I have uninstalled and reinstalled it several times and still says the same thing.I have also did the java test on pogo and it says i have the lastest version.I have also cleared the tempory files in java and it still don't work.I'm also having the same problems on other game sites
I was able to play Pogo games in Firefox with no problems until recently, now when attempting the popup opens with no problem and appears to be loading. Unfortunately, it never gets past the appears to be loading stage.
I received one error message referring Java, so I downloaded the latest version in case that was the issue, however still no resolution.
I have tried the suggestion of flushing the Java cache and removing the check from "keep temporary files" to no avail.
I have same problem, one day it was all working fine forever, and then it just quit working. No matter what site I go to using Java my browsers all close upon game load.
It seems like Pogo, needs to fix their problem as I did everything as well. I did tests, checks, and removed temps, cache's everything and Booom nothing. Always closes. I also went to pogo Sun Java and everything is fine so what's up????
Lordsbaby2001 On Pogo
i cannot connet to pogo Why???
I'm wondering if the KB963027 update to IE has anything to do with this? I have the same problem and had done all the known to me fix actions. However, I installed Firefox and voila, works there. /Roy
