Whirlpool 15.2 cu. ft. / 430 liter Upright Freezer EV150FXKQ Logo
marlyn wallaker Posted on Apr 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do you get tap to add freon - Whirlpool 15.2 cu. ft. / 430 liter Upright Freezer EV150FXKQ
Jason Kennidy
Level 3:
  • Whirlpool Master 1,344 Answers
  • Posted on Apr 27, 2012
Jason Kennidy
Whirlpool Master
Level 3:
Answers
1344
Questions
0
Helped
369898
Points
4021
I always get my tap valves at www.apdepot.com. The best ones to use are bpv-31 bullet piercing valves, because they are capable of piercing a variety of line sizes, so your not limited to your tap location and find the most accessable spot.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
I have a kenmore model 970-254291 freezer. It runs all the time and has recently stopped freezing new foods. Could this be corrected by recharging the r131a?
dont know --what is r131a doesnt exist --- is it low on freon -has someone tapped a line in the past ---your system is a closed /sealed system that only needs freon if someone damages a line/component causing leak --yours can be any thing fron dirty condenser--failing thermostat--compressor or fan[s]
ISN'T GETTING COLD NEED TO KNOW HOW TO ADD FREON PLEASE ?
Unless you have a lot of expensive refrigeration tools and a license to recover and buy freon, then you need a serviceman.
How to refill R134 Freon
you have first put in a line tap. If the freezer system has been open it must be put in vac. to get moisture out. Then with interior coil exposed put in a few oz and start compressor. with compressor running add while watching interior coil/ you add slow til coil frosts to 3/4 then your done
If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_4ed9a6c8e57209e6
2helpful
How do you recharge the feon in a chest feezer?
Well you could get a tap valve, like a bpv-31 and tap into the low side, which is the bigger line coming out of the compressor, but your going to need some freon guages, not ones for automotive, but for a/c or refridgeration, freon, and a recovery pump.; just these parts and tools alone your paying more than what it be to have someone over.
Jun 05, 2012 • Freezers
1helpful
2answers
How do i add freon to system
Get a saddle valve like THIS ONE. Sand down the suction line or compressor ear and attach the valve. Connect hoses to the valve and add some freon. The low side pressure should be around
5 PSI.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I cannot find the location to add freon to my frigidare uprifgt freezer model number-ffu16f9cw1
Most freezers do not have a tap from the factory to add aditional freon...you will need specialized equipment to be able to do that...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
1helpful
Frigidaire Chest Freezer Model LffC1466DW4. Inside coils are frozen and copper pipes underneath are frozen. I have let set unplugged for 2 days and tried again. Ice forms within a few hours. How do you...
you dont want to add any more freon to it to start with
it either has to much in it or the thermostat is not turning it off and making it run to long, you need to see what temperature you are getting in the freezer and what suction pressure the unit is running on to determine if it is over charged
2helpful
Need to add freon
  • if you are tapping into a sealed system, then you use the larger of the two copper lines coming out of the side of the compressor (this is the low pressure line, the compressor pulls from this side).
  • clean off the copper tubing with some fine sandpaper before installing your tap.
  • it is very easy to over fill a system with freon, so i would recommend pulling down the system to -30 psi and holding for at least 20 minutes. then add a known amount of freon to the system.
  • let it run for a while, it will take a little time to get the temperatures down.
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
