In dell system when i turn on the system then it says in power save mode press any key from keyboard and move mouse,when i press the nothing happens,system is not turning on
My monitor says it is in power save mode and that I need to move my mouse or hit a key. When I do that nothing happens with the monitor. It stays dark.
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
1. Check to be sure your "Number Lock" or
"Function Lock" keys aren't lit. These can lock out certain parts of
your keyboard. If either of these is lit, press them to unlock the
locked portion of your keyboard. These can be found at the top right on
a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your
computer. This will only work if your computer isn't frozen. If your
mouse doesn't move, press the power button on your Dell until the
computer turns off. Press it again to restart. If the issue was lack of
memory or a locked program, this will unlock your keyboard. Continue to
Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over
and sliding the battery release latch. Slide the battery out and
replace after one minute.
Have a good one!
Step 2
Save
Step 3
Step 4
Remove
the battery if you're using a laptop by turning the laptop over and
sliding the battery release latch. Slide the battery out and replace
after one minute.
You can hit Window+U at the Welcome Screen, this will turn on the on-screen keyboard. Reinstalling the drivers should fix the problem
............................................................ Also to enter save mode, when the system powers up hold down F8 Key. Use your arrow keys to move to "Safe Mode" and press Enter key.
Dell monitors automatically go into power-save mode after a preset
amount of time when the computer is inactive. The Dell monitor will go
completely black, instead of showing a screensaver. This doesn't mean
that your Dell computer
has shut down. Instead, this allows your monitor to essentially turn
off until it's needed again. You can change how long it is before the
Dell monitor goes into power-save mode by changing your display
settings.
Step 1
Press
any key on your keyboard or move your mouse. Either will turn off
power-save mode. Alternately, you can press the power button on your
Dell computer tower or laptop.
Step 2
Press
any key a second time if the monitor goes from power-save to stand-by
mode. Stand-by mode allows the screensaver to appear.
Step 3
Enter
your user name and password into the login prompt if your computer
requires a login. Press "Enter" to begin using your Dell computer.
Step 4
Change
the display settings on your Dell monitor to prevent your monitor from
going into power-save mode prematurely. Right-click anywhere on your
desktop and choose "Properties." Click the "Screensaver" tab and press
"Power." Beside "Turn off Monitor," choose a time amount from the
drop-down list and press "Apply."
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
