You may be able if can enter the menu to change from Spanish back to English--(very old set) by using vol or channel buttons to navigate--this is not certain but possible--idioma is word to look for--language.
Testimonial: "Thanks so much! That helps"
I need to kno how to het my Magnavox converter to work my colortrak plus tv
SOURCE: 1987 RCA Colortrak 2000 Television
Line 1 is Channel 91, Line 2 is Channel 92 - you can select them directly using the remote
SOURCE: Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
SOURCE: my RCA Colortrak Plus will not turn on
hi
If no standby light you have defective unregulated power supply! and regulated power supply! needs to diagnose.
Thanks!
SOURCE: Converter box remote will not program
i have a admiral tv and i'm wanting to program my remote that goes to my converder box to the tv is there anyway i can do that?
