LG LMV1925 Microwave Oven Logo
David Ziemer Posted on Nov 30, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not heat.
I have a LG LMV1925 1000 watt Microwave. It is 13 months old and just stop heating food. Everything else works fine. Already check power settings and it still stops if the door is open, so I don't think it is the door switch. What else could it be?
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Nov 30, 2006
Anonymous
Expert
Level 2:
Answers
50
Questions
5
Helped
181475
Points
176
Hi I've been out of the microwave repair business for a few years now, but the technology has remained virtually the same as far as I know. You obviously have some knowledge of them, as you know about the safety switches in the door. Microwave ovens are actually a very simple device, to test it, put a coffee cup of water inside, and set the unit on high for one minute. A second or two after you hit the start button, you should hear a fairly loud "bong" noise, and a hum that continues untill the time runs out. That noise is the magnetron starting up, and if that noise does not happen, then the magnetron or related circuitry is probably bad. NEVER open up the oven, as the magnetron may be charged, and must be discharged by a technician. If the sounds that I described are present, then the water should be boiling or close to it in one minute, if not,then something I've never seen has gone wrong. Assuming you had a year warranty on it, I know from experience that if you contact Goldstar customer service by phone, or letter, they will often extend their warranty a month or so to keep happy customers. Its worth a try. Hope this helps you out. P.S. Never operate a microwave without something inside (Non metalic)
MICROWAVE IS NOT HEATING--EVERYTHING IS WORKS FINE
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may have to replace the capacitor as well. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Microwave not heating anything? everything else work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgshg
1helpful
Stopped heating
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Microwave taking much longer to heat food
The microwaves are produced by what is known as a KLYSTRON TUBE. Like anything, early failure is possible. There is also the possibility that the transformer or electronic circuit providing the correct voltage to the KLYSTRON has failed, either from over-use, manufacturing defect, or leakage from the KLYSTRON enclosure, which creates heat.
With microwaves being as CHEAP as they are, replacement should not be an issue.
MH1160 Whirlpool Microwave Stopped Heating
Are you getting 110VAC on the primary leads of the high voltage transformer when you press "Start" to begin cooking?
If not, yhen it may simply be a bad cook relay (I do board repair) or a bad bottom or inside top door switch. See http://www.microwavecontrol.com/doorsw.htm
E-mail me via my site for more free help.
William E. Miller, AS-EET
[email protected]
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
My GE microwave just stopped heating the food. Everything else is working fine.
heatman101
dghjd
2helpful
3answers
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
