Computers & Internet Logo
Anonymous Posted on Apr 25, 2012
Burning cds fine but session will not close any idea what to do?
Tsstcorp cddvdw ts l633a ata everythinng else works good except just will not close audio cds ive tried different cd types and everything
  • Anonymous Apr 27, 2012
    Sorry about not saying as well I have tried roxio Nero and cyberlink and all have the same result....
Davit Mamyan
Level 3:
  • Master 552 Answers
  • Posted on Apr 25, 2012
Davit Mamyan
Master
Level 3:
Answers
552
Questions
0
Helped
102778
Points
1896
Change your burning programm
    Tried three already no luck .... That was first thing I did lol
1 Related Answer
Anonymous
  • 11 Answers
  • Posted on Dec 12, 2009
SOURCE: not working TSSTcorp CDDVDW TS-L632H ATA Device
hi.. pls remove the CD ROM from the laptop . insert once again.check the bios status ....
Tsstcorp cddvdw ts-t633a hp touchsmart does not burn music cd
Hi
The most likely cause of this issue is that the CD drive has gone faulty so will require you to replace the unit
Regards
Cliff Cook
MCP
Tsst corp cddvdw ts-l633a ata device has stopped working. when i put in a cd or dvd nothing happens.
is problem with your cd/dvd drive try once to unplug and plug the drive in the notebook
Tsstcorp cddvdw ts-l633a scsi cdrom device not recognized, why?
Either the data cable at its back is badly plugged in (refit the data cable correctly) or the unit itself is faulty - replace it, it cannot be repaired.
My DVD drive (TSSTcorp CDDVDW TS-L633A ATA Device) doesn't read or write DVDs but it can read CDs? Please Help!
you need to have software to do all of that like ROXIO or DVD FLICK--- you can download for FREE at WWW.CNET.COM >DOWNLOADS>VIDEO SOFTWARE>DVD SOFTWARE then choose FREE and be sure it is compatible with your OS
If this was helpful please indicate so
2answers
I have problem with optical drive TSSTcorp CDDVDW TS-L633A ATA Device,,in windows it says: Windows cannot load the device driver for this hardware. The driver may be corrupted or missing.
The fact you have Windows already installed on this machine should indicate that the D drive was working before unless this is a new hardware? If it used to work before, then something must have attacked the system and corrupted it (virus or other malware). If your system is clean it could be just a hard disk error. You can run chkdsk utility by right clicking on the C drive, properties, tools and error checking option. Good luck.
Not working TSSTcorp CDDVDW TS-L632H ATA Device
3helpful
2answers
Code 19 on Tsstcorp Cd DVDw Ts L633a Ata Device windows vista. how can i fix it please?
Please use the Microsoft fix it tool to fix the registry vaules it will resolve your issue
TSSTcorp CDDVDW TS-L633A IDECDROMTSSTCORP_CDDVDW_TS-L633A________________AC00____&30B14D09&0&0.1.0 Failure using the VxD loader. TSSTcorp CDDVDW TS-L633A Windows cannot start this hardware...
if the usb ports are not working its down to a motherboard fault. cd/dvd roms need 12 volts and 5 volts to work if a voltage is not right it will give you code 19 to 25. have you had something short out on the usb side, i.e some device you have used in the past. usb stick tec. as sometimes it can blow a fuse on the main board, these can be replaced if you know how to solder and find the fuse that has gone.
9helpful
2answers
TSST corp CDDVDW TS-L633a Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
ASUS Nootebook M/n.F80cr.
CD/DVD Driver : 4M-TSSTcorp CDDVDW TS-L633A.
Bios V.204.
WindowsXP.Pro.pack3
My Computer not to Look on windows.
I neet driver softwere to solve this problem.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
