There is a remark " unknown device " appears to the device manager, pls. help me how to solve it
SOURCE: IBM THINKPAD a31 do not boot up
I just read a thread on this. Try pulling the mini pci network card. Or maybe one of your memory slots is bad so you could pull a memory card out and try swapping things there. Help for these issues can be found on the Lenovo site. http://en.wikipedia.org/wiki/Red_states_and_blue_states
there are also user manuals and hardware replacement manuals there.
Be careful wth the mother board. It could also be your problem but hopefully it's something easier. mother boards have been known to fail when the computers are handled in such a way as to flex them.
SOURCE: ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646¤t-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
SOURCE: drivers problem
you will need to download and install all drivers from IBM download website.
See :
Lenovo Support & downloads - Drivers and software - ThinkPad
try this http://driverscollection.com/?H=ThinkPad%20A31p&By=Lenovo
also have you went into the bios and seen if you audio driver was disabled ?
SOURCE: hi i've just done a clean install of windows xp on
You can get them here
http://www-307.ibm.com/pc/support/site.wss/MIGR-55386.html
