Aux-in jack is used to play another device such as an Ipod or other sources through your Jensen player, using it as some sort of an amplifier. Look for another port on your Jensen player that says "audio out" or "Spkr" (means speakers) to plug in her headphones. If you can't find any of these ports then you might have purchased a n actual boom box, which does not have the capability to play through headphones, sorry about that.
Good day. You will need tyo get yourself a "sterio to RCA" cable. You will then plug the sterio plug into your laptop, and the RCA cables into the back of your receiver, lets say,AUX. Then set your receiver to the aux input and play your music through your receiver. Hope this helps
your laptop has an audio output jack that is 1/8 inch sterio .. your sound system likely has RCA input jacks .. you can get a cable from radio shack that has a 1/8 inch (3.5mm) sterio plug on one end and two RCA plugs on the other ..
plug the 1/8 inch jack into your computers audio output (headphone jack) .. the RCA plugs will connect to the AUX (analog) input on your sound system .. select AUX on your sterio system to select the computers input .. now you should have great sound from your computer . the computer likely provides only sterio information so the multi (7) channel feature of your sound system will have to fake it ..
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad and they will send a repair tech to replace the pad for free, even if you are out of warranty.
does sterio system have aux in tv has rca outs use rca cable from tv outto aux in on sterio system ok the selct aux input on sterio turn it up
cheak tv settings for outout options ok
hey no it wont work in full 5 .1 cuse samsung tv has rca outs use rca to mini sterio jack but your speakers syetm for pc is set up for fronts rears center chs 3 sepret sterio plugs for pc so u can only use one of these sets front with woof not all 5 nope unless ther was a controller in it that ran off 1 sterio plug to controll all 5 built into the logitec speakers but i pretty sure 3 sterio plugs right ? u understand best best dvd samsung x 40 those rock
