I have replaced water pump, inlet water valve, completely cleaned unit, adjusted cube size and cycle time.
Unit made ice for about two days and has not worked properly since.
I am looking at probable solutions and am thinking maybe it's the hot gas valve. Is that a good place to start?
Where else is best to focus on?
Unit is Scotsman brand, home ice machine, model DCE33
Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
