Bosch Classixx WFC 2465 Front Load Washer Logo
Posted on Nov 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing the brushes when the motor is off
Do you have to dismantle the motor on the bosch classixx 1200 to change the brushes or can it be done without? if do how, thanks
Anonymous
Level 3:
President:
  • Master 1,294 Answers
  • Posted on Apr 10, 2009
Anonymous
Master
Level 3:
President:
Answers
1294
Questions
Helped
901111
Points
3465
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1805
Points
How do you remove the brushes on a Bosch Classixx 1200 washing machine?
How to replace brushes on a classic 6 1200
Disconnect the power
disconnect hoses
lay machine on it's left side
remove back cover screw and cover
slip belt off pully
unplug motor wires
undo bolts holding motor
pull motor to rear of machine
revome motor to bench
locate brush housings
undo retaining clip and slide out old brush
fit new brush
replete with other brush
reasonable in reverse of removal
2helpful
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
2helpful
Bosch Classixx WAE24162GB/03 motor not working, have cxd brushes
There is a thermal cutout in the motor, but unfortunately it is not resettable.
The only way to be sure if it is faulty, is to check it for continuity with a meter, if it is open circuit, it can be bypassed, but this then leaves the motor unprotected, but it will prove if the fault is in the motor, or elsewhere.
It could be a blown track on the control board caused by the brushes shorting, in addition, to an open circuit thermal cut-out.
2helpful
Hi there, have got a bosch 1200 classixx WF02466GB/01 - pumps working but will not spin the drum. Belt is ok and drum does move when you push it.
To make sure it is not due to water left in the drum, remove the filter, and clean.
If it still does not spin, then it is more than likely that the brushes need replacing in the motor..
You will have to remove the motor to check them..
If they are less than 3 or 4 mm long, then they need changing.
Hope this helps.
4helpful
Drum not working on bosch washing machine
I would say that the brushes want replacing in the motor, access to the motor is by removing the rear panel, remove the belt, and undo screws securing motor, remove motor, brushes are located at rear end of motor.
Please rate my solution.
Thanks
1helpful
Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
2helpful
Bosch classixx 1200 fills, drains, but won't wash ?
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Plz rate my solution.
Thanks.
17helpful
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Thanks
Brushes
I just did this and had to take the motor off because I couldn't get to one of the brushes. It was easy to get off (only 2 bolts) and just as easy to put back on. Taking the motor off made life much easier as fitting the brushes is fiddly.
Brushes
most brushs are screwed to the back of the motor which are very easy to replace,other are inside the motor and you have to dismanttle the motor.i hope this is what you wanted to know.your question wasnt clear.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
