Loud noise during the spin cycle. Repairman says it is a bearing in the transmission. The part is cheap but the labor is expensive enough that it may not make any sense to repair.Loud noise during the spin cycle. Repairman says it is a bearing in the transmission. The part is cheap but the labor is expensive enough that it may not make any sense to repair.
Anyone have a repair schematic for this?? Thanks!Anyone have a repair schematic for this?? Thanks!
AnonymousJan 04, 2009
My Maytag washer made a clicking noise during the spin cycle for a few days and just now shut off completely just before completing the first spin cycle.
I have a Maytag Model MAVT446AWW and just put in a new bearing due to a leak. Now I have the clicking noise during the spin cycle if the tub has a a larger load in it. Larger means more than two or three items. The clicking starts when the spin cycle gets up to its full speed. I have a Maytag Model MAVT446AWW and just put in a new bearing due to a leak. Now I have the clicking noise during the spin cycle if the tub has a a larger load in it. Larger means more than two or three items. The clicking starts when the spin cycle gets up to its full speed.
AnonymousMay 22, 2009
Have similar problem.........Won't agitate or spin ........I'm thinking a bearing kit will solve the problem.......Maytag Washer HAV2558AWW Have similar problem.........Won't agitate or spin ........I'm thinking a bearing kit will solve the problem.......Maytag Washer HAV2558AWW
AnonymousMar 27, 2014
The water is not spinning out during the spin cycle and the unlock lid button is going off.The water is not spinning out during the spin cycle and the unlock lid button is going off.
AnonymousMar 31, 2014
occasionally maytag washer off balance during spin cycleoccasionally maytag washer off balance during spin cycle
You can't post conmments that contain an email address.
Re: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Possible that the grinding noise comes from the drum, irregular movement or broken paddles. You can try and attempt only if equipped with a fundamental understanding of the working . I shall give you some tips to this click 1..: Washing Machine
Sounds like the transmission seal had failed sometime back and has leaked the lubricant causing the transmission to overheat and now possibly seizing the gears, if this is the case the transmission will have to be replaced. Depending on the age of the washer, (5 years or less) you should contact Maytag to see if they will compensate you by way of furnishing the new transmission for free, but you will be responseable for the labor charge from a tech to do the replacement.
If they will not cover the part, you will probably be better off to replace the washer than to invest in the cost of a new trans and labor.
Good Luck !
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
